When I use the object.RotateAboutZ Pivot, Angle method, my CellElement always rotates around the Z axis in the global coordinate system. How can I rotate my CellElement around the Z axis of the Toggle AccuDraw coordinate system instead of the Z axis of the global coordinate system? The premise is that I used app.Matrix3dInverse(app.CommandState.AccuDrawHints.GetRotation(View)) in front of this method; we have obtained a matrix of Toggle AccuDraw coordinate system.
The problem has been solved, please advise.
Here are some of the codes:
Matrix3d rotateAboutViewNormalAtOrigin; Matrix3d rotation; //当前精确绘图矩阵 Matrix3d rotation1; //当前精确绘图矩阵的逆矩阵 rotation = app.CommandState.AccuDrawHints.GetRotation(View);//获取当前精确绘图矩阵 rotation1 = app.Matrix3dInverse(rotation); pUorToMdl = app.Transform3dFromMatrix3dAndFixedPoint3d(rotation1,ref pntOrigin); rotateAboutViewNormalAtOrigin = app.Matrix3dFromVectorAndRotationAngle(rotation.RowZ, Angle);//围绕当前坐标系Z轴旋转 elemCell.Transform(app.Transform3dFromMatrix3dAndFixedPoint3d(rotateAboutViewNormalAtOrigin, m_atPoints[0])); //设置围绕原点方法 mdlTMatrix_transformPoint(ref m_atPoints[1], ref pUorToMdl);// 将某一点旋转到当前坐标系内的坐标
Answer Verified By: Hua.Yang
