I have the object is the default Angle cell is 0 ° I want to rotate the object to the horizontal that coincides with the X axis of Microstaion V8i,
My idea is to select objects using MicroStation V8i selection tool
This can be handled by VBA Microstation, hope everyone in the forum help me, thank you very much
Doan Nguyen Thuc said:I want to rotate the object to the horizontal that coincides with the X axis of Microstaion V8i
MicroStation has built-in tools for element rotation. You don't need to write any VBA.
Could you please guide me how to rotate, I want to operate quickly with multiple objects at the same time. Thank you
Doan Nguyen Thuc said:Could you please guide me how to rotate
Post your question to the MicroStation Forum.
as Jon wrote, if there is no a specific reason to use VBA, it's probably better to ask in MicroStation Forum and to discuss how to do it using normal MicroStation tools.
Doan Nguyen Thuc said:I have the object is the default Angle cell is 0 ° I want to rotate the object to the horizontal that coincides with the X axis of Microstaion V8i,
On the other hand, based on this information, I am not quite sure whether it can be solved by user tool only.
I recommend to share an example file. If 0° is the first (rotated) text, it will require to analyse text inside the cell and to rotate the cell in an opposite direction, where VBA will be required.
With regards,
Jan
It's like rotating using the V8i' RE command, but Re does not rotate multiple objects at once, I want to use VBA to rotate multiple objects at once, by selecting select then VBA will automatically rotate the object. in the north, because I do not know about programming so I can not write it myself, I hope people help me to save more time. I have the v8i file attached to this link. Best regards
www.mediafire.com/.../DC03.dgn
I like to use a macro I found on the askinga part of this website called Active Angle Assistant. I think it does what you want.
Code... We're the good guys now.
Hi Doan,
thanks for the file, it's as I expected: The worse scenario where cell are unrotated but texts inside cells are rotated randomly. I am curious how such drawing was created?
This code should work, but be aware it's just quickly written draft:
Option Explicit Public Sub RotateCell() ProcessAllCellsInActiveModel End Sub Private Sub ProcessAllCellsInActiveModel() Dim ee As ElementEnumerator Set ee = GetCellsInActiveModel Do While ee.MoveNext If ee.Current.Type = msdElementTypeCellHeader Then ProcessCell ee.Current.AsCellElement End If Loop End Sub Private Function GetCellsInActiveModel() As ElementEnumerator Dim esc As ElementScanCriteria Set esc = CreateScanCriteriaCellsOnly Dim ee As ElementEnumerator Set ee = ActiveModelReference.Scan(esc) Set GetCellsInActiveModel = ee End Function Private Function CreateScanCriteriaCellsOnly() As ElementScanCriteria Dim esc As New ElementScanCriteria esc.ExcludeAllTypes esc.IncludeType msdElementTypeCellHeader Set CreateScanCriteriaCellsOnly = esc End Function Private Sub ProcessCell(cell As CellElement) Dim textInCellRotation As Double textInCellRotation = AnalyzeTextAngleInCell(cell) Dim inversionRotation As Double inversionRotation = textInCellRotation * -1 cell.RotateAboutZ cell.Origin, inversionRotation cell.Rewrite End Sub Private Function AnalyzeTextAngleInCell(cell As CellElement) As Double Dim ee As ElementEnumerator Set ee = cell.Drop Do While ee.MoveNext If ee.Current.Type = msdElementTypeText Then Dim textRotation As Matrix3d textRotation = ee.Current.AsTextElement.rotation Dim rotX As Double, rotY As Double, rotZ As Double, scl As Double Matrix3dIsXRotationYRotationZRotationScale textRotation, rotX, rotY, rotZ, scl AnalyzeTextAngleInCell = rotZ Exit Function End If Loop AnalyzeTextAngleInCell = 0 End Function
Thanks for the help of Mr. Jan, can you make VBA help me a little bit, because this VBA changed all the wrong rotating objects contained in the DGN file, I just want to change the angle for the objects are selected by Element selection only.
Doan Nguyen Thuc said:can you make VBA help me a little bit
honestly and with all respect, no. You started the discussion in Programmin forum, so there is an expectation you have at least basic programming knowledge. To modify working code to enumerate selection set and not active model is quite simple task. Or you can implement ILocateCommandEvents object to create own element selection tool. There are examples in MicroStation VBA help how to do it.
There is also another aspect: We all participate in discussions in our free time. I have verified several times that to provide anything more than what I am able to write (or often to stick from existing code snippets) in a few minutes, e.g. to modify code accordingly to people requirements, because they are not willing to invest own time to study and enhance their development skills, ends not only with lack of mz time, but also with general expectation people can ask and somebody will write a code for them.
