Does anyone in here know how to expand the ProjectWise configuration variable from a MCB?
If I use the function "activeworkspace.expandconfiguration" i get the local (translated) value. ex. c:\pwwork\<username>\<dmsfolder>
I would like to have the value pointing to ProjectWise. ex. pw.server.com\documents\<project>\<folder>
When I look in MicroStation workspace configuration, the value is exactly what I'm looking for, but it's not the value I receive in my VBA macro.
I want to retrive the master files folder path, and then set MS_MARKUPPATH relative to the masterfiles folder.
Finn Mejding said:When I look in MicroStation workspace configuration, the value is exactly what I'm looking for, but it's not the value I receive in my VBA macro
If we would see your VBA code, we might be able to help.
Finn Mejding said:Does anyone in here know how to expand the ProjectWise configuration variable from a MCB?
I don't understand the question. What's an MCB?
There is a ProjectWise Programming Forum that might be a better place to post that question.
