Is there a tool which works in Microstation Connect which rotates elements to specific angles?
I had one for V8i but it won't load into Connect.
dainel40 said:I tried using the files on the .zip files
There are two .mvba files in that ZIP. You should unzip both to somewhere that MicroStation can expect to find them, such as \Organization\Standards\Macros
dainel40 said:... it is not working for me
What doesn't work? What have you tried? Do you see an error message in the Message Center or a warning dialog?
What happens when you key-in vba run getangle?
