I'm struggling with placing a cell along an arc in VBA.
I have a Complex Chain where I will place a cell along the whol chain with a fixed distance.
I have solved the rotation on the "Line" part of the chainm but having trouble with the arc.
The rotation is almost correct, but almost doesn't count :-)
Any one have a suggestion?
The code snippet for placing the cell:
Sub showLineElm(LinElm As ComplexStringElement) Dim elm As ElementEnumerator Dim aelm As ArcElement Dim lelm As LineElement Dim oPH As PropertyHandler Dim lastsegment As String Dim streng As String, streng1 As String Dim start As Point3d Dim skala As Point3d Dim oCell As CellElement Dim z As Integer Dim ant_cell As Double, distance As Double Dim vinkel As Double Dim mtrxRotation As Matrix3d skala.X = 1 skala.Y = 1 skala.z = 1 If LinElm.Type = msdElementTypeComplexString Then If LinElm.IsTraversableElement Then Set elm = LinElm.GetSubElements Do While elm.MoveNext
Select Case elm.Current.Type Case msdElementTypeLine Set lelm = elm.Current.AsLineElement lastsegment = "Segments[" & (lelm.VerticesCount - 2) & "]." Set oPH = CreatePropertyHandler(lelm) oPH.SelectByAccessString (lastsegment & "Start") start = oPH.GetValueAsPoint3d oPH.SelectByAccessString (lastsegment & "Direction") streng = oPH.GetValue vinkel = Degrees(CDbl(streng)) mtrxRotation = Matrix3dFromAxisAndRotationAngle(2, CDbl(streng)) Set oCell = CreateCellElement2("cellname", start, skala, True, mtrxRotation) ActiveModelReference.AddElement oCell ant_cell = lelm.Length / 0.854 ant_cell = ant_cell \ 1 distance = 0 For z = 1 To ant_cell distance = distance + 0.854 If distance > lelm.Length Then Exit For End If start = lelm.PointAtDistance(distance) Set oCell = CreateCellElement2("cellname", start, skala, True, mtrxRotation) ActiveModelReference.AddElement oCell Next z
Case msdElementTypeArc Set aelm = elm.Current.AsArcElement Set oPH = CreatePropertyHandler(aelm) oPH.SelectByAccessString ("SweepAngle") vinkel = oPH.GetValue mtrxRotation = Matrix3dFromAxisAndRotationAngle(2, vinkel) start = aelm.StartPoint Set oCell = CreateCellElement2("cellname", start, skala, True, mtrxRotation) distance = 0 oCell.Transform Transform3dFromMatrix3dAndFixedPoint3d(mtrxRotation, start) ActiveModelReference.AddElement oCell ant_cell = aelm.Length / 0.854 ant_cell = ant_cell \ 1 For z = 1 To ant_cell distance = distance + 0.854 If distance > aelm.Length Then Exit For End If start = aelm.PointAtDistance(distance) Set oCell = CreateCellElement2("cellname", start, skala, True, mtrxRotation) oCell.Transform Transform3dFromMatrix3dAndFixedPoint3d(mtrxRotation, start) ActiveModelReference.AddElement oCell Next z End Select Loop End If End IferrExit:End Sub 'showLineElm
Finn Mejding said:I'm struggling with placing a cell along an arc in VBA
Here's an example VBA project that may help...
It probably doesn't do exactly what you want, but it's a good place to start. The startling bit is probably the use of a B-Spline curve to help calculate point-at-a-distance and tangent-at-a-distance for each cell placement.
Answer Verified By: Finn Mejding
Thanks Jon, that really helpme.
I have the rotation matrix in place now, just need to fit the numger of cells.
Finn Mejding
CAD Manager
Railway and Metro
COWI
