My command successfully interrogates elements. It gathers an ElementAgenda and then ElementAgenda::Hilite to show user the elements that matched some criteria.
ElementAgenda
When the ElementAgenda is destroyed the elements remain hilighted in MicroStation's views. If user wants to interrogate elements using new criteria, I want to remove the highlights from the elements selected by an earlier query. But at that point the ElementAgenda holding the highlighted elements is history: it has been destroyed.
Is there a quick way to find existing hilighted elements and clear their highlight state, either...
Jon Summers said:Is there a quick way to find existing hilighted elements and clear their highlight state, either...
No, if you don't keep the agenda around there's nothing else that's keeping a list of which elementRefs have their hilite state set.
Would it make sense for your tool to make the result the current selection set?
-B
Brien Bastings said: if you don't keep the agenda around there's nothing else that's keeping a list of which elementRefs have their hilite state set
Too bad!
Brien Bastings said:Would it make sense for your tool to make the result the current selection set?
The tool ElementAgenda may be a filtered version of an existing Fence contents or Selection Set. I feel that it would confuse the user if a new Selection Set were to appear.
I could make the ElementAgenda global, but that seems an unfortunate overhead for a single tool that's part of a much bigger app.
I am confused.
I can not find ElementAgenda.ClearHilite() function.
But there is ElementAgendaDisplayable.ClearHilite()
So, if ElementAgenda is distroyed there still exists ElementAgendaDisplayable
However, this does not solve the problem.
Lets say, user selects some elements. I start my addin and want to search reModel for any selected elements.
It has to be a way to do that.
Maybe, using SelectionSetManager. BuildAgenda(ref Bentley.DgnPlatformNET.ElementAgenda agenda)
Not sure.
regards
Nenad
Nenad Poljcic said:I can not find ElementAgenda.ClearHilite()
The MicroStationAPI help is not always easy to use. My preferred approach is to use the Search pane and click on the xxx Struct item (in this case, the ElementAgenda Struct Reference)...
Nenad Poljcic said:I start my addin and want to search reModel for any selected elements
That is solved by the SelectionSet Manager or by ElementAgenda::BuildFromElementSet.
However, that's not my problem. When you use ElementAgenda::Hilight the highlighted elements are not added to a Selection Set. They belong to the ElementAgenda. But, when the ElementAgenda is destroyed, the highlights remain. Since the highlighted elements are not members of a Selection Set, there's no way to retrieve them.
Jon Summers said:I could make the ElementAgenda global, but that seems an unfortunate overhead for a single tool that's part of a much bigger app.
Yes, and it's problematic too as the ElementRef of the agenda entries could become stale (user deletes element, compresses file, etc.). A safer approach would be to keep a vector of ElementId and try to find the elements by their id at the point where you need to clear the hilite.
I'd use DgnModelAppData to save the vector of ElementId for the elements from each model that are hilited as opposed to a global (goes away if model deleted, etc.).
