Hi everyone,
I am trying to write an MDL for Microstation V8i (Select Series 4) which should transform the heights according to a certain height-modelling for different element-types.
I am using a Loop over all graphical Elements with a callback-function, which first creates an Duplicate of the MSElementDscr-Object
mdlElmdscr_duplicate(&newedP, edP);
first and afterwards calls the specific Transformation-function according to the element-type.
It works already for some Elements, like e.g. for Line_3d-Elements:
Private int HoehTrans_htransLine ( MSElementDescr **edPP // <=> Zeiger auf MSElementDescr-Objekt ) { int test1=FALSE, test2=FALSE; // Height-Transformation test1=test_transHPoint(&(*edPP)->el.line_3d.start); test2=test_transHPoint(&(*edPP)->el.line_3d.end); if(test1==TRUE && test2==TRUE) return TRUE; else return FALSE; }
The same thing should be done for Line_String_3d-Elements as well with the following Code:
Private int HoehTrans_htransLineString ( MSElementDescr **edPP // <=> Zeiger auf MSElementDescr-Objekt ) { int test=FALSE i; int pnum; DPoint3d** pList; // Speicher fuer Punktliste allokieren pnum=(*edPP)->el.line_string_3d.numverts; pList= (DPoint3d**) calloc(pnum, sizeof(DPoint3d*)); for(i=0; i<pnum; i++) pList[i]= (DPoint3d*) calloc(1, sizeof(DPoint3d)); // Hoehen-Transformation test=HoehTrans_transHList(&(*edPP)->el.line_string_3d.vertice, pnum); if(test==TRUE) return TRUE; else return FALSE; }
The connected height-transformation test-function Looks like this:
Private int test_transHList ( DPoint3d** pointPL, //<=> IN/OUT: zu transformierende DPunkt3d-Liste int pnum // => IN: Anzahl der Punkte in Liste ) { double dh=150.0; int ret=FALSE, i; if(pointPL!=NULL) { for(i=0; i<pnum; i++) pointPL[i]->z+=dh; ret=TRUE; } return ret; }
My Problem is now, that I get an Compiler-error in the function "HoehTrans_htransLineString" for the Line
- test=HoehTrans_transHList(&(*edPP)->el.line_string_3d.vertice, pnum);
that says:
"conversion of Parameter 1 from 'DPoint3d (*)[1]' in 'DPoint3d **' not possible"
Because the number of Vertices in the Element is not only "ONE", why is the '(&(*edPP)->el.line_string_3d.vertice'-Parameter of the LineString-Element not a field-pointer 'DPoint3d**' ??
Did I understand something wrong, or is it just a simple error in the Code?
In case of the Line-Element I rewrite finally in the callback-function the changed MSElementDscr-Object to file using and would like to do that with the LineString in the same way:
mdlElmdscr_rewrite(newedP, NULL, filePos);
Many thanks in advance for your help!
Best regards,
Ines Wieland
Ines Wieland said:Is there any side-effect when using the function mdlElmdscr_transform()for the current transformation? Or is there any effect on the whole complex element by this function?
mdlElmdscr_transform follows h.next pointers. When modifying individual entries in an element descriptor chain, or components of a complex element you would typically want to use mdlElmdscr_duplicateSingle before calling mdlElmdscr_transform to isolate the component. You then use mdlElmdscr_replace to update the original.
Answer Verified By: Ines Wieland
Many thanks Brien, that solves the displacement-problem!
I changed the mdHoehTrans_htransComplex-function in the following way and it works now:
Private int HoehTrans_htransComplex ( MSElementDescr **edPP // <=> Zeiger auf MSElementDescr-Objekt ) { MSElementDescr *pComponent = (*edPP)->h.firstElem; MSElementDescr *pPartial; int elType = mdlElement_getType(&(*edPP)->el); int test = -1; if(elType != CMPLX_STRING_ELM && elType != CMPLX_SHAPE_ELM) return -1; // Loop over all components while(pComponent) { elType = mdlElement_getType(&pComponent->el); // Duplicate the Component for element-changes if(mdlElmdscr_duplicateSingle(&pPartial, pComponent) != SUCCESS) return retErr; // call transformation-function according to element-type switch(elType) { case LINE_ELM: //case 3 test=HoehTrans_htransLine(&pPartial); break; case LINE_STRING_ELM: //case 4 case SHAPE_ELM: //case 6 test=HoehTrans_htransLineString(&pPartial); break; case CMPLX_STRING_ELM: //case 12 case CMPLX_SHAPE_ELM: //case 14 test=HoehTrans_htransComplex(&pPartial); break; case ARC_ELM: //case 15 test=HoehTrans_htransEllipse(&pPartial); break; default: // other cases return -1; break; } // Ende SWITCH-Block if(test != SUCCESS) return -1; // replace changed Element-Descriptor mdlElmdscr_replaceDscr(&pComponent, pPartial); // go to next Element pComponent = pComponent->h.next; } // Validation to update boundary-box etc. mdlElmdscr_validate((*edPP), mdlModelRef_getActive()); return SUCCESS; }
Many thanks and best regards to all commentators
