In porting code from Select to CONNECT< I have a tool that uses mdlSystem_newDesignFile(). I'm attempting to replace the use of that function with ISessionMgr calls. I can only get a new .dgn file to open in "read-only" mode. I know there are a few situations that result in a file being opened "read only" but they don't apply (at least I don't think they do).
// BeFileName outFileName; if ( SUCCESS != mdlFile_find(&outFileName, fullFileName.c_str(), NULL, NULL)) { wprintf(L"Error locating file\n"); } else { // open the file StatusInt status; DgnDocumentMonikerPtr dgnMon = DgnDocumentMoniker::CreateFromFileName(fullFileName.c_str()); if (!dgnMon.IsValid()) { wprintf(L"!dgnMon.IsValid()\n"); return true; } DgnDocumentPtr dgnDoc = DgnDocument::CreateFromMoniker(status, *dgnMon, DEFDGNFILE_ID, DgnDocument::FetchMode::Write, DgnDocument::FetchOptions::Default); DgnFilePtr dgnFile = NULL; if (dgnDoc.IsValid()) { wprintf(L"dgnDoc.IsValid()\n"); DgnFileStatus dgnStatus; DgnFilePtr newFile = ISessionMgr::GetManager().FindDesignFile(dgnStatus, fullFileName.c_str(), L"Default", GRAPHICSFILE_UStn, true); if (dgnStatus == SUCCESS) { DgnFileP pFile = ISessionMgr::GetManager().GetMasterDgnFile(); ISessionMgr::GetManager().SwitchToNewFile(*dgnDoc, L"Default", GRAPHICSFILE_UStn, true, false, false, false); } return true; } }
The current (active) file and the one I'm trying to open are not the same file.
Bruce
Bruce Reeves SRNS said: I'm attempting to replace the use of [mdlSystem_newDesignFile] with ISessionMgr calls
Why?
I figure that [eventually] the "mdlXXX" functions will all be deprecated in favor of the newer MicroStation API classes, plus I just want to know how to do it....
Bruce Reeves SRNS said:I figure that [eventually] the "mdlXXX" functions will all be deprecated in favor of the newer MicroStation API classes
You're probably correct, and at that point (after you've installed the SDK for some future CONNECT Update N) your code using mdlSystem_newDesignFile will fail to compile and you can look for the method of whatever class implements the equivalent functionality.
Hi Bruce,
I have not tested these new classes, but your code seems to be fine. CreateFromFileName and CreateFromMoniker methods can be replace by one CreateFromFileName method, but I guess there is no difference in terms of functionality.
Maybe you can check dgnDoc instance what access it reports, it can help to distinguish whether read-only access is defined when moniker is created or just assigned when the files are switched.
With regards,
Jan
I wouldn't be too concerned about this. Most of the mdl functions that could no longer be supported have already been removed or had their parameters changed. It's just not worth trying to expunge every mdl function from MicroStation and it's applications; if it ain't broke don't fix it...
I think you can call DgnDocument::CreateForLocalFile?
MSCORE_EXPORT int mdlSystem_newDesignFile (WCharCP fileName) { return ISessionMgr::GetManager().NewDesignFile (*DgnDocument::CreateForLocalFile(fileName), NULL, false); }
OK - I'll stick with mdlSystem_newDesignFile().
Brien Bastings said: ISessionMgr::GetManager().NewDesignFile (*DgnDocument::CreateForLocalFile(fileName), NULL, false);
BTW: I don't see that function in the API documentation.
