In V8i MicroStation, we are using resource fonts that have non-standard characters defined, like a centerline symbol ("L" positioned in the center of a "C"). These symbols do not typically exist in the TrueType fonts. I see that CONNECT can construct any fraction by taking a numerator and denominator text and "stacking" them (offsetting the origins of the respective parts) and creating a TextNode of the parts. So, before I begin to explore the possibility of doing something similar, I just wanted to ask if what I'm going to try might work.
I'm thinking that I can create a TextNode with two pieces of text: "C" and "L". The default mode would be to insert a break (paragraph or line break) to build the TextBlock. Once that is done, I was going to try and re-position the second "run" (i.e. "L") to move it to the center of the "C" and slightly below. I'm not sure I can get to the origin of the run via the API, but that is what the test is about.
I'm exploring how to convert text from resource fonts to TrueType fonts. There are a few "special" resource font symbols that have no equivalent TrueType symbol. However, I *think* I can manually create them. I realize that they may not be "editable" because of the abnormal positioning, but at this point I think I can live with that...
Bruce
Bruce Reeves SRNS said:In V8i MicroStation, we are using resource fonts that have non-standard characters defined, like a centerline symbol ("L" positioned in the center of a "C"). These symbols do not typically exist in the TrueType fonts
There are font design tools you can use to create your own fonts for Windows and other operating systems. Fontographer, for example, has been around for decades. Of course, that leaves you with a Type 1, TrueType, OpenType or Type 3 font library to distribute to your users; but that's no different to distributing a DGN resource font.
An advantage to creating your own TrueType font is that other apps., such as Word, can display the same glyphs.
Hi Bruce,
If you are in need of replacing resource fonts, then you may wish to consider these options.
HTH,Bob
For #1, See: ..\examples\Annotations\TextExample\TextExampleData.cpp:312: textBlock->AppendStackedFraction (L"151", L"253", StackedFractionType::HorizontalBar, StackedFractionAlignment::Middle);
