Hi guys,
I'm testing the latest OpenRoads Designer SDK 10.04.00.48 with VS2015.
I'm attempting to build the SDK supplied example project using Visual Studio 2015.
On the right I see a list of Bentley assemblies that are not found. I think this is why the project build fails. Any suggestions?
Benzi
Hi Benzi Papo,
Glad to see you were able to resolve the issue.
One additional note worth mentioning. In your first screen capture of the ORD developer shell title bar (consumes and overrides portions of the MicroStation SDK shell) please note in the title bar the part "Standard User". This indicates that you are running as a standard user; shortcut property or starting the script; without full admin privileges where if set to Run as Administrator you should expect to see: "Elevated User". Please check the start properties of your shell (shortcut or scripts) to ensure Run as Administrator is set so your compiled binary output files can be placed in appropriate program application folders; e.g. mdlapps folder; that requires for administrative privileges.
HTH,Bob
