I'd like to get a DgnTextStyle from an TextElement ,but that returns IsNull().
TextElement txtElement = dgnmodel.FindElementById(el.ElementId) as TextElement; DgnTextStyle textstyle = DgnTextStyle.GetSettings(dgnfile); DgnTextStyle dgntext = DgnTextStyle.GetById(txtElement.ElementId,dgnfile);
Shaopu.Cao said:DgnTextStyle dgntext = DgnTextStyle.GetById(txtElement.ElementId,dgnfile);
GetById wants the ID of the text style, not the ID of the text element. The documentation is confusing because it shows the data type of the argument as ElementId — but that's just an alias for a 64-bit unsigned integer.
GetById
ElementId
Look up a text style in the DGN file collection …
DgnFile dgnFile = Bentley.MstnPlatformNET.Session.Instance.GetActiveDgnFile(); DgnTextStyle style = DgnTextStyle::GetByName ("Shaopu.Cao", dgnFile); // use style.Id
Answer Verified By: Shaopu.Cao
TextElement txtEle = dgnmodel.FindElementById(el.ElementId) as TextElement; ElementPropertiesGetter txtgetter = new ElementPropertiesGetter(txtEle); TextPartIdCollection textParts = txtEle.GetTextPartIds(new TextQueryOptions()); TextBlock txtBlock = txtEle.GetTextPart(textParts[0]); ulong id = txtBlock.GetProperties().TextStyleId; ElementId txtId = new ElementId(ref id); DgnTextStyle txtStyle = DgnTextStyle.GetById(txtId, Session.Instance.GetActiveDgnFile()); textdescript = txtStyle.Name;
Thank you very much for your answer. The Bentley technical support teacher in China gave the answer above. I passed the test here. Thank you. The document really puzzles me.
