Hi All,
I am trying to find a way to set the feature definition of geometry objects based on their feature names.
So a centreline with a feature name starting with 'CL' would be given the 'Geom Centreline' feature definition etc..
I don't think it can be done in Openroads itself automatically? I could do it manually but there are hundreds of objects with varying names.
I have looked through both the Microstation and Openroads Designer API docs that are provided with the Openroads SDK, but I can't find ANY references to feature definitions or Openroads-specific properties of geometry objects.
Can anyone help?
Many thanks
Travis
Hi Travis,
I have a crude mvba that bulk applies feature definitions, but it simulates doing it manually and is much slower than id like.
The SDK would be much better - i believe "ObjectSettings" is what feature definitions are referred to in ORD?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
