When I attempt to insert a button into a ButtonGroup using mdlDialog_buttonGroupInsSubItem(), MicroStation crashes. I can use mdlDialog_buttonGrouGetSubInfo(), mdlDialog_buttonGroupSetSubInfo(), and mdlDialog_buttonGroupDeleteItem() just fine. My ButtonGroup is defined such:
DItem_ButtonGroupRsc BUTTONGROUPID_Arch_Doors = { NOSYNONYM, NOHELP, MHELP, ITEMHOOKID_ButtonGroup, NOARG, 0, 6, 3, 0, 0, -1 /*WHITE_INDEX*/, "", "srsDialogInfo.comboBoxChoice", { //IconType, IconID, commandNumber, commandSource, value, mask, arrayIndex, attributes, label {RTYPE_Icon, ICONDID_1, NOCMD, LCMD, 1, NOMASK, 0, 0, "3 x 7 Door"}, // "DOOR" } };
In the _OnInit() hook, I'm querying the single "button" item to fill in the values for the new button I want to insert. To try and eliminate any "conflicts" I delete that button and then insert attempt to insert the "new" one. I can query the existing button and remove it without issue - when the code executes mdlDialog_buttonGroupInsSubItem(), it causes MicroStation to crash. If I do not remove the original button in the group, the code still crashes.
bool MyButtonGroupHandler::_OnInit(DialogItemInitArgsR init) { UInt32 value = 1; UInt32 mask = NOMASK; UInt32 arrayIndex = 0; UInt32 attributes = 0; RscType rscType = RTYPE_Icon; RscId rscId = ICONDID_1; int cmdSource = LCMD; IconRsc *pIcon = NULL; //WCharP pLabel = NULL; WChar Label[256]; CommandNumber cmdNumber; UInt32 index = 0; mdlDialog_buttonGroupGetSubInfo(Label, &rscType, &rscId, &pIcon, &cmdNumber, &cmdSource, &value, &mask, &arrayIndex, &attributes, NULL, GetRawItem(), index); mdlDialog_buttonGroupDeleteItem(GetRawItem(),index); // crashes if I include this line WCharCP newLabel=L"NewLabel"; mdlDialog_buttonGroupInsSubItem(newLabel, &rscType, &rscId, &cmdNumber, &cmdSource, &value, &mask, &arrayIndex, &attributes, NULL, GetRawItem(), -1, true); // fails return true; }
The crash report contains this;
Exception String: 'Access Violation'
Wrote a mini-dump type 0x4 to "c:\Temp\1\Bentley\MicroStation\10.0.0\MiniDump.dmp".Stack dump:Exception: 0xc0000005 @ 0x14bb2668 0: 0000004068ffca80 00007ff814bb23bf 0000000000000008 0000000000000008 0000000000000000 0000000000000010 RtlReAllocateHeap+0x408 1: 0000004068ffcbe0 00007ff814bb22ba 000001d69ac695a0 0000000000000008 0000004068ffcf20 000001d6b32ddd30 RtlReAllocateHeap+0x15f 2: 0000004068ffcc20 00007ff810fb2bf9 0000000000000128 000001d6b32ddd30 00000000533ed530 0000004068ffcd30 RtlReAllocateHeap+0x5a 3: 0000004068ffcc50 00007fffe06cc570 0000000000000128 00007ff810fae88b 00000000ffffffff 000001d6b32ddd30 realloc_base+0x39 4: 0000004068ffccc0 0000000052bdcfd4 000001d6b3077a20 00000000533ed530 0000000000000000 0000000000000000 memutil_realloc+0x20 5: 0000004068ffccf0 00000000529e1bb4 000001d6b32ddd30 00000000ffffffff 000001d69ae7fd10 0000000000000058 dlmSystem_mdlReallocWithDescr+0xf4 6: 0000004068ffcd90 00000000529e3a70 000001d6b32ddd30 ffffffffffffffff 00007fffc8b0ab28 00007fffc8b0ab28 basicText_undoField+0x1324 7: 0000004068ffce00 00000000529e387f 0000004068ffcf90 0000000000000000 000001d69ba4adf0 00000000529e1190 mdlDialog_buttonGroupInsSubItemDesc+0x1e0 8: 0000004068ffce80 00007fffc8b040c9 00007fffc8b0aa00 0000004068ffcf30 0000000049636f6e 0000000049636f6e mdlDialog_buttonGroupInsSubItem+0x7f
Bruce
Hi Bruce,Could you zip and post the exception.log and minidump.dmp file from your exception in this thread?
Also, if you have a simplified stand-alone "test case" having the minimal items necessary to reproduce the crash and are able to zip and attach to this post I can also review it.Thank you,Bob
Here you go....
RobertHook-buttonGroupInsertTest.zip
Thank you for the memory dump and test case. I will try to review as quick as possible.
Bob
Were you ever able to investigate this issue further?
