V8i View Attributes Settings Macro for 2D Design Files
This macro will change the View Attributes settings for a 2D design file.
Copy and paste into your text editor, modify as needed.
'   Created by Carl Kastner
'   20180913
'   MicroStation V8i SS4 | Win 7
' Turns off/on (False/True) attributes on the View Attributes dialog.
Sub main
    Dim startPoint As MbePoint
    Dim point As MbePoint, point2 As MbePoint
'   Send a keyin that can be a command string
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 ACSTriad True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Background False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 BoundaryDisplay False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 ClipVolume True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Constructions True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 DefaultLighting False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Dimensions True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 DataFields True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Displayset False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 FastCells False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Fill True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Grid False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 LevelOverrides False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 LinesStyles True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 LineWeights True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETHUDMARKERVISIBILITY ON 0 ""\"""
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Patterns True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Tags True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Text True"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 TextNodes False"
    MbeSendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Transparency True"
End Sub
Parents Reply
  • Jan,
    Thank you for the info/history.
    Imagine stepping into an organization and dealing with thousands of design files where they do not use dgnlib files, no Cell/Text/Dimension Libraries, arrowheads are created with many small lines instead of fills, when once there were cells they are now dropped to elements, dealing with elements/objects from ACAD and/or Building Designer/TriForma, and on it goes.
    And I am tasked with standardizing it all. Its a combination of: Oh, the horror and what a challenge!
