[v8i VBA] Create View Independent TextNode
This question was never truly answered over 5 years ago, so I am asking again.
I can select a text node in the Element Information dialog box and change the text node to View Independent. And then, the entire Text node retains its rotation as the view is rotated. But the code to build a text node specifically prevents one from assigning View Independence to a text node.
If you assign it to each element, then, they rotate about their origins but their origins, being View Dependent, continue to rotate and the result is what I call the Ferris Wheel effect. Like the benches on a Ferris Wheel, the text elements remain upright, but eventually, the upper line of text is below the lower line of text. And the angles in between, often result in the two pieces of text overlapping each other.
How is one supposed to create an element which is clearly supported by the software, in VB, that does what we need? A true View Independent Multi-line Text Node!
