I can see classes ItemType and Picklist in MstnPlatformNET help. What I can't see is the way to associate a Picklist with an ItemType property. That is, how do I write code that informs MyItemType.MyProperty that its values should be restricted to those specified in MyPicklist?
With MicroStation CONNECT Update 12, Picklists are added to the C++ MicroStationAPI. The functionality is similar to the .NET API. However, C++ doesn't provide the CustomProperty::PickListName property to assign a Picklist to an Item Type Property.
Hi Jon,
Thank you very much for your questions. You just need to write similar code below:
MyProperty.PickListName = APickListNameWhichIsInPickListLibrary;
This isn't in the blogs which I've written. I'll write a new blog includes it in the future.
Colin
Answer Verified By: Jon Summers
Colin Wang said:This isn't in the blogs which I've written
Tell us more about your blogs!
Please access below link to get more new blogs which are very helpful.
communities.bentley.com/.../weblog
Yongan.Fu said:Please access below link to get more new blogs
That link now leads to this page, which has a single topic: Bentley Institute Going Digital Event. What happened to the other blogs?
Colin Wang said:MyProperty.PickListName = APickListNameWhichIsInPickListLibrary;
I can see that in the MstnPlatformNet documentation. Unfortunately I can't find an equivalent method for C++ in the MicroStationAPI documentation.
Jon Summers said:I can't find an equivalent method for C++ in the MicroStationAPI documentation
From Update 13 we can use CustomProperty.SetPickListName. Hurrah!
Hi Jon Summers,
Having received notification of your most recent reply on this thread, I am adding the response below to close the loop on this point within this thread too.
Jon Summers said:Yongan.Fu said:Please access below link to get more new blogs That link now leads to this page, which has a single topic: Bentley Institute Going Digital Event. What happened to the other blogs?
A number of previous Blogs located under Developers and Programming (a general public programming blog area) were specific to MicroStation Programming and relocated (one time only) to their respective location: MicroStation Programming Blogs.
Bob
