I have recorded a macro in microstation v8i ss4 and I have created a command button through userform in visual basic editor. But I am not able to place the command button in the drawing and run the macro. How should I link the command button to the macro so that when I place the command button in the drawing and when the user clicks on that button the macro should run.
Look in the help file for 'Loading and running a VBA macro' - you need to load and display your form. The command button does not get placed into the drawing, you would display your UserForm and work from there.
Narayan Kavinatamai said:I am not able to place the command button in the drawing
You're thinking of the Excel way of doing things. With MicroStation VBA, you design a UserForm to hold your buttons and other UI components.
Here's an example VBA project. Open the project in your IDE and look at module modMain.
modMain
