MicroStationAPI help lists a number of methods under topic Active Settings. For example,
static BentleyStatus GetValue (bool &value, ActiveBoolParams paramName) Gets the value of an active MicroStation setting of type boolean
However, those methods are in namespace ActiveParams not ActiveSettings. Please make the documentation more accurate and helpful!
Hi Jon,
In documentation One Header can contain information from multiple classes. Hence it is not necessary to have one to one mapping of class name and documentation header.
In this case Documentation header suggest how can we get/set the Active Settings at that instance, that is why name is Active Settings.
Rohit Dighe said:In documentation One Header can contain information from multiple classes
That's as may be. In this case, the headline Active Settings does not refer to a namespace or class. However, the functions that follow are part of the ActiveParams namespace or class. But no mention is made of ActiveParams.
The help documentation is intended to help. In this case, I'm asking you to include the ActiveParams namespace.
Agreed, I will make a change in documentation to add the ActiveParams information. I have filed a defect for tracking
Answer Verified By: Jon Summers
