I ran into a problem recently where I needed to edit text within various textnodes. Many of those text nodes were nested inside of cells. Searching the communities and the rest of the internet basically returned other people running into the same problem that I was running into. In short, there are known issues with using VBA to edit textnodes. The best information is summed up in this archived thread which has links to another thread that no longer exists:
https://communities.bentley.com/products/programming/microstation_programming/f/archived-microstation-v8i-vba-forum/28652/update-node-text
Long story short, the "Bad Element" error persists when trying to edit .TextLine(1) or (2) etc. Effectively, this makes it impossible to update the text of an existing text node using VBA. So in the interest of helping the next person who runs into this problem here is how I managed to work around what appears to be a decade old known bug.
Sub NodeInCell() Dim TempEle As Element Dim tEle As TextElement Dim tnEle As TextNodeElement Dim cEle As CellElement Dim sArray() As Element Dim s As Long Dim tEE As ElementEnumerator Dim oEE As ElementEnumerator Dim oSC As ElementScanCriteria Set oSC = New ElementScanCriteria oSC.ExcludeAllTypes oSC.IncludeType msdElementTypeCellHeader Set oEE = ActiveModelReference.Scan(oSC) sArray = oEE.BuildArrayFromContents sStart = LBound(sArray) sEnd = UBound(sArray) For s = sStart To sEnd Set cEle = sArray(s) Do While cEle.MoveToNextElement Set TempEle = cEle.CopyCurrentElement If TempEle.Type = msdElementTypeTextNode Then Set tnEle = TempEle Set tEE = tnEle.GetSubElements If tnEle.TextLine(3) = "text 3" Then Do While tEE.MoveNext If tEE.Current.AsTextElement.Text = "text 1" Then tEE.Current.AsTextElement.Text = "new 1" tEE.Current.Rewrite ElseIf tEE.Current.AsTextElement.Text = "text 2" Then tEE.Current.AsTextElement.Text = "new 2" tEE.Current.Rewrite ElseIf tEE.Current.AsTextElement.Text = "text 3" Then tEE.Current.AsTextElement.Text = "new 3" tEE.Current.Rewrite End If Loop End If End If Loop Next s End Sub
Basically, don't use ".TextLine" at all. Pick apart the textnode as if it was a cell and interact with each text element as if it is not part of a textnode or cell. You just have to dig down to them first. Hopefully this is helpful to somebody else. After all the struggles I read about online (and my own) it seemed like this was something worth capturing for posterity.
Cheers,
Ian
Hi Ian,
Thank you for reporting this issue.
I have tested the .Textline method to assign new text values to Textnodes within cells and can confirm the issue as well as the workaround to use an enumerator to iterate the textelements within a textnode.In V8i a runtime error occurs while in CONNECT Edition the method is executed without an error but without modifying the text element.
I have filed Defect # 999672 to address this issue.
Best regards,Artur
Artur,
Thanks for testing it out and entering the defect. I should have mentioned it was an issue with V8i. SS2, SS3 and SS4. Upgrading to CONNECT is on next year's project list. From my research it sounded like the issue had already been reported. I wonder what happened to that original defect report. Doesn't matter now since this issue is back in the queue. I hope anybody running into the situation before it's fixed can find this. Solving this cut 2-4 man hours per day out of the production group that is updating our old format files.
Can confirm this is still an issue in Update 16
See new post here
