Hi all,
I would like to get the count of the number of elements selected in MicroStation VBA.
I have already used a scan criteria to get the elements I want. Now the issue is that I would then iterate through the selected elements using the ElementEnumerator, and add up all the lengths of the LineElements in my selection set.
I know I can get the total length of the selected elements using CommandState.MeasureResult1.
I want to also get the count or number of selected elements.
Before i was using
Dim elmCount As Long elmCount = UBound(ActiveModelReference.GetSelectedElements.BuildArrayFromContents) +1
This works, but I imagine it might not be optimal.
I have also explored mdlSelect_numSelected() function by calling it from my VBA code,
'Declared Mdl function Declare Function mdlSelect_numSelected Lib "stdmdlbltin.dll" (ByVal windowP As Long) As Long Dim windowPval As Long Dim elmCount As Long windowPval = 1 elmCount = mdlSelect_numSelected(windowPval)
The image i attached shows the two values i am trying to obtain from within my VBA code.
The code i used above with the Declare statement doesn't work as i get an error
Run-time error '49':
Bad DLL calling convention
This is the error i am getting.
I'm not sure what i need to pass the mdlSelect_numSelected() as an argument as my VBE editor suggested a
Long
I am currently using MicroStation V8i SS4, version 08.11.09.829, on Windows 10, build 1809, 64bit.
Thank you.
