[CONNECT C++] How do I write a Boolean formatter for TextField::CreateForElement()?
TextField::CreateForElement(..., ..., formatter, ...) works fine for my Item Type properties that store text. I don't need to supply a  formatter (i.e. formatter is nullptr) for the text to be displayed correctly.
I have recently added a Boolean Item Type property.  The default formatter for Boolean shows text True or False.  How do I write a formatter to display, say, Yes or No?
  • Jon, take a look at BooleanClass in MstnPropertyFormatter schema.
    Specifically the "BoolWord" property supports the following integer values; a value of 2 will format a boolean as "Yes" or "No".
        <ECClass typeName="BooleanClass" isDomainClass="True">
            <BaseClass>FormatterBaseClass</BaseClass>
            <BaseClass>VariableBindingClass</BaseClass>
            <ECProperty propertyName="BoolWord" typeName="int" displayLabel="Display As">
                <ECCustomAttributes>
                    <StandardValues xmlns="EditorCustomAttributes.01.00">
                        <ValueMap>
                            <ValueMap>
                                <Value>0</Value>
                                <DisplayString>(Default)</DisplayString>
                            </ValueMap>
                            <ValueMap>
                                <Value>1</Value>
                                <DisplayString>True/False</DisplayString>
                            </ValueMap>
                            <ValueMap>
                                <Value>2</Value>
                                <DisplayString>Yes/No</DisplayString>
                            </ValueMap>
                            <ValueMap>
                                <Value>3</Value>
                                <DisplayString>On/Off</DisplayString>
                            </ValueMap>
                            <ValueMap>
                                <Value>4</Value>
                                <DisplayString>Enabled/Disabled</DisplayString>
                            </ValueMap>
                        </ValueMap>
                    </StandardValues>
    Answer Verified By: Jon Summers
