i am add Timer in form in Additional Controls... the timer event in MicroStation v8 using VBATimer.ocx file. but it is not display MicroStation CONNECT Edition
SnapShot is attached in below link
/resized-image/__size/143x85/__key/communityserver-discussions-components-files/343173/8880.GridNavigationForum.png
The image you supplied does not appear to be displaying at a size that it can be read. Would you be able to supply another copy of the image along with a more detailed explanation for what you are trying to perform here. It would also be helpful if you supply the exact version of MicroStation CONNECT Edition you are using.
https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
It's impossible to use 32-bit controls in 64-bit VBA.
