Microstation v8i (08.11.09.833)
I took an example from help vba. I entered points to try but the macro hangs on
vec1 = Vector3dFromMatrix3dTimesVector3d(oview.Rotation, Vector3dSubtractPoint3dPoint3d(pt2, pt1))
... what's wrong?
Option Explicit Sub anglept2() Dim activeangle As Double Dim computedangle As Double Dim oview As View Dim pt1 As Point3d Dim pt2 As Point3d pt1.X = 527203.091598784 pt1.Y = 5064287.03824722 pt1.Z = 0 pt2.X = 527197.378828332 pt2.Y = 5064287.03824722 pt2.Z = 0 computedangle = GetActiveAngleFrom2Points(pt1, pt2, oview) activeangle = Radians(computedangle) Debug.Print "angolo attivo = " & activeangle End Sub Function GetActiveAngleFrom2Points(pt1 As Point3d, pt2 As Point3d, oview As View) As Double Dim vec1 As Vector3d, vec2 As Vector3d Dim angle As Double 'get vectors in plane of view vec1 = Vector3dFromMatrix3dTimesVector3d(oview.Rotation, Vector3dSubtractPoint3dPoint3d(pt2, pt1)) vec2 = Vector3dFromXY(1#, 0#) 'duplicate keyin logic angle = Degrees(Vector3dAngleBetweenVectorsXY(vec2, vec1)) If angle < 0# Then angle = angle + 360# End If GetActiveAngleFrom2Points = angle End Function
thank you
Massimo Callegher said:the macro hangs
Dim oview As View ... vec1 = Vector3dFromMatrix3dTimesVector3d(oView.Rotation, Vector3dSubtractPoint3dPoint3d(pt2, pt1))
Where do you set oView? If oView Is Nothing, then oView.Rotation is guaranteed to fail.
oView
oView Is Nothing
oView.Rotation
Answer Verified By: Massimo Callegher
.. oops thank you very much too distracted, it's time to retire :)
