I have a macro that scans a model and will detach any reference files that are live nested, missing and turned off. Essentially I only want reference models that belong to the file to remain.
This works fine until there are no references left to detach and I get the below error. How do I exit the subroutine?
Sub nestedRef() Dim currentRef As Attachment Dim refAttachments As Attachments Set refAttachments = ActiveModelReference.Attachments For Each currentRef In refAttachments Debug.Print currentRef.AttachName If Not currentRef.ElementsVisible Then refAttachments.Remove currentRef End If If currentRef.NestLevel > 0 _ Or _ currentRef.IsMissingFile Then refAttachments.Remove currentRef End If Next End Sub
Hi Simon,
Simon Biddle said:that scans a model and will detach any reference files
I am not sure what do you mean by "that are live nested":
So what attachment exactly you want to remove? I do not see any such functionality in the code.
Simon Biddle said:How do I exit the subroutine?
Nearly always, when you start to think "how to exit loop" (for each is not subroutine!), it represents wrong approach and implementation. For each loop iterate a collection (e.g. attachments in this case) and process all items. The righ approach is to test whether you want to do something with item or not.
An expection from "nearly always" is when you need to check for a first occurence of some condition. In such case, use break to exit the loop (exit for in your case, because for each loops is used).
Simon Biddle said:This works fine until there are no references left to detach and I get the below error.
The problem is not "no references to detach"! Your code is wrong, I see two main problems:
When working with attachments, you have to use exact procedure:
Until these tests are valid, attachment object cannot be used as model object.
Also you at first detach attachment, so CurrentRef is probably not valid anymore, and in the next step you try to use it.
One extra note: I am not sure whether it's possible to remove attachments inside for each loop. All languages I know do not allow to remove an item (attachment) from a collection (attachments) in for each loop, because it invalidates an iterator. But I have not tried it practically. Anyway, in my opinion you should better specify conditions when the attachment should be removed. When it will be clear, it will be time to discuss whether another approach should be used.
With regards,
Jan
Simon Biddle said: I only want reference models that belong to the file to remain
Reference attachments belong to a DGN model, not to a file.
An attachment may itself have attachments. From the point of view of that attachment, its attachments are direct. From the point of view of the top-level model, those are nested attachments. Since an attached model is read-only, you can't directly affect nested attachments.
Enumerate the attachments of a DGN model. Remove those that meet your criteria. I, like Jan, am a little confused about your criteria for removal. Write a function that encapsulates your removal logic...
Function IsCandidateForDetach (ByVal oAttachment As Attachment) As Boolean IsCandidateForDetach = False Debug.Print oAttachment.AttachName If oAttachment.IsMissingFile Then IsCandidateForDetach = True ElseIf oAttachment.IsMissingModel Then IsCandidateForDetach = True ElseIf Not oAttachment.ElementsVisible Then IsCandidateForDetach = True End If End Function
I only want to retain Attachments that are visible and have No Nesting. Having a criteria of NestLevel > 0 gives me access to those that are live nested. Is there another way to achieve this?
Thanks Jon your function works great though I just added a line for the attachments that have the Nested Attachment set to Live Nesting. However I assume I am not iterating over the function correctly in my For Each statement. How do I handle when there are no more Attachments that match the criteria?
Dim currentRef As Attachment Dim refAttachments As Attachments Sub detachRefFile() Set refAttachments = ActiveModelReference.Attachments For Each currentRef In refAttachments If IsCandidateForDetach(currentRef) = True Then ActiveModelReference.Attachments.Remove currentRef End If Debug.Print currentRef & AttachModelName Next RedrawAllViews End Sub Function IsCandidateForDetach(ByVal oAttachment As Attachment) As Boolean IsCandidateForDetach = False Debug.Print oAttachment.AttachName If oAttachment.IsMissingFile Then IsCandidateForDetach = True ElseIf oAttachment.IsMissingModel Then IsCandidateForDetach = True ElseIf Not oAttachment.ElementsVisible Then IsCandidateForDetach = True ElseIf oAttachment.NestLevel > 0 Then IsCandidateForDetach = True End If End Function
Simon Biddle said:I only want to retain Attachments that are visible and have No Nesting.
Ok, now it makes sense. "have no nesting" is completely different from original "are live nested". "Have no nesting" is a feture of an attachment of current level, whereas "are live nested" describes references at least one level below under current level (and it requires different code to be handled).
Simon Biddle said: However I assume I am not iterating over the function correctly in my For Each statement.
Why do you assume it? Is there any error message? Do you have any test case where the code does not work correctly?
For each loop always iterate a whole collection, unless an early escape is used (which is not the discussed case). As I wrote earlier, I am not sure whether it's allowed to delete the collection member, but in such case I guess the code will crash.
A couple of bad styles and bugs found in your code, my modified version is:
Option Explicit ' It's bad style to declare variables outside a scope where they will be used. ' Alwyas declare variable at the same place where it will be used for the first time, ' but not earlier. Sub detachRefFile() Dim refAttachments As Attachments Set refAttachments = ActiveModelReference.Attachments Dim currentRef As Attachment For Each currentRef In refAttachments If IsCandidateForDetach(currentRef) = True Then ' Two bugs were here: ' - Using & makes no sense, it's not valid VBA code ' - When the attachment is removed, it has not been valid anymore, so to use it later causes error Debug.Print currentRef.AttachModelName ActiveModelReference.Attachments.Remove currentRef End If Next RedrawAllViews ' MicroStation redraws views automatically, so redraw is not needed End Sub Function IsCandidateForDetach(ByVal oAttachment As Attachment) As Boolean IsCandidateForDetach = False Debug.Print oAttachment.AttachName If oAttachment.IsMissingFile Then IsCandidateForDetach = True ElseIf oAttachment.IsMissingModel Then IsCandidateForDetach = True ' Are you aware of all conditions hidden in this property? ' ElementsVisible marge both display off, frozen level and others. ElseIf Not oAttachment.ElementsVisible Then IsCandidateForDetach = True ElseIf oAttachment.NestLevel > 0 Then IsCandidateForDetach = True End If End Function
Answer Verified By: Robert Hook
Hi Jan
Thankyou for looking at this for me and ironing at the bugs, the code is working great.
