my code is the following:
uint? WT = new uint(); Bentley.DgnPlatformNET.ElementPropertiesGetter propGet = new Bentley.DgnPlatformNET.ElementPropertiesGetter(Element); WT = propGet.Weight;
and the result is 0 ,although the weight is bylevel?
Does somebody has any idea?
Best regards
Axel
Hi Axel,
what CE version do you use?
Jan
I'am using CE Update 10,
Regards Axel
By default, it should return 0. Have you tried changing via property pane.
Mangesh
Hi Mangesh,
Mangesh.Shelar said:By default, it should return 0.
I am not sure how it's implemented in CE API, but historically when element property is "by level", -1 is returned.
When talking about ElementPropertiesGetter, how it can be checked whether a property (color, style, weight) is set to ByLevel?
With regards,
Let me take this with my colleague, I will let you know soon. Thanks.
You have declared WT as as an un-signed "int". Wouldn't it need to be a "signed" int?
Bruce Reeves SRNS said:You have declared WT as as an un-signed "int". Wouldn't it need to be a "signed" int?
No, both in native and managed API the getter returns UInt32 for Weight value ... at least it's written in doc ;-)
A thoughtful conjecture, but the MstnPlatformNet tells us …
public uint Weight { get; }
Jan Šlegr said:Historically when element property is "by level", -1 is returned
But that doesn't work with a uint. So how do we find if a property is by level?
uint
There's a Weight structure that has a ByLevel field. The Weight struct has an Explicit operator that creates a Weight from an int or uint. I don't know if that would automatically fill the ByLevel field.
Weight
ByLevel
Explicit
int
Unfortunately, there's no example and MstnPlatformNet documentation is terse.
Jon Summers said:There's a Weight structure that has a ByLevel field.
But how this structure can be obtained from ElementPropertyGetter (both in C++ and NET)? As far as I understand the getter should be (together with setter) used to access common element properties.
Jan Šlegr said:historically when element property is "by level", -1 is returned
Hmm. Then things have changed. I *do* see this enum:
enum { COLOR_BYLEVEL = 0xffffffff, COLOR_BYCELL = 0xfffffffe, STYLE_BYLEVEL = 0x7fffffff, STYLE_BYCELL = 0x7ffffffe, WEIGHT_BYLEVEL = 0xffffffff, WEIGHT_BYCELL = 0xfffffffe, LEVEL_BYCELL = 64, };
Maybe the variable is not "big" enough (e.g. UInt32) ?
