Hello Everyone,
Our organisation have just upgraded our MicroStation v8i SS3 to MicroStation Connect edition version 10.10.00.23.
I am having trouble with my v8i MDL apps since its not working in my connect edition.
I am not a programmer and although I am learning VBA, I have been unsuccessful in trying to replicate the same MDL app function in VBA. If someone can easily modify and recompile my old V8i MDL app so it can work in my CONNECT edition, that will be great thanks. or if someone can guide me to write a VBA version of that MDL app, that'll be very beneficial for my learning too.
I have attached my old v8i MDL app as a zip file. datstmp.zip
Basically, we used to call this MDL by using our custom tool with key-in as "LV=2;CO=3;WT=0;textstyle active AN18;MDL Load datstmp;place stamp" to place the 2 line of texts.
and we used to call the same MDL by using our another custom tool with key-in as "LLV=2;CO=3;WT=0;textstyle active AN18;MDL Load datstmp;update stamp" to update the current file location and current date,time.
Output used to look like this pic:
And also here's my initial attempt on replicating the same function in Connect vba, here's my codes:
Public Function GetDgnFilename(ByVal modelRef As ModelReference) As String GetDgnFilename = vbNullString GetDgnFilename = modelRef.DesignFile.FullName End Function Sub PlaceDateTimeStamp() Dim Path As String Dim CustomPath As String Dim oDate As Date Dim CustomDate As String Dim MyTime Dim CustomDateTime As String Path = GetDgnFilename(ActiveModelReference) CustomPath = "File:\\ " & Path oDate = Now() CustomDate = Format(oDate, "Medium Date") ' or "Short Date" or "Long Date" or your own custom date format MyTime = Time 'Returns a Variant (Date) indicating the current system time. CustomDateTime = "Date: " & CustomDate & " " & MyTime Debug.Print CustomPath Debug.Print CustomDateTime End Sub
Any help will be much appreciated.
(Thank you Jan Slegr for your comments in my other post)
Thank you
Shyam.
Shyam Lama said:Output used to look like this pic
Take a look at MicroStation Text Fields. You may be able to achieve your requirements without any programming.
Here's an example DGN file:
TextFieldFileExample.dgn
Hi Shyam Lama,
When migrating to CONNECT Edition there are a number of considerations, workflows, and paths that may be taken. So, first I agree with Jon Summers that "Option 1: MicroStation CONNECT can effectively replace this prior customization need/feature/functionality" - directly with MicroStation Text Fields (a powerful new feature to explore and leverage), here are a few Text Field Wikis that may help you get started.
For any/all New or Existing/Advanced users, I completely recommend reviewing information we are organizing in this (one single entry point) blog post: Advancing to CONNECT Edition. We will continuously editing and improving this link for all New and Existing/Advanced users to make all their options and information current and helpful as possible.
HTH,Bob
Robert Hook said:here are a few Text Field Wikis
Sift the Wikis that discuss Text Fields from those about Data Fields. The terminology is similar but the semantics are different. Data Fields are 20th century technology and have nothing to do with Text Fields.
Hi Robert & Jon,
Thank you for your reply. Much appreciated
I was testing today with Text Fields and I will test it further if it can fix my issue.
One thing I noticed with Text fields that the texts with field are highlighted with grey color background, is there anyway I can remove that background highlight please? Thanks
Shyam
Shyam Lama said:One thing I noticed with Text fields that the texts with field are highlighted with grey color background, is there anyway I can remove that background highlight please?
In Preferences dialog, go to Text category and switch on Hide Field Background option.
Jan
Hi Jan,
Thank you for your reply and apologies for a very late response.
Although I found a way to create the same output via TEXT FIELDS. It wasn't the best option for my workplace since we have 1000's of drawings already with the File+Date stamp I have shown above and everytime someone was modifying those drawings, they needed a button to simply update the current file path and current date/time.
So I went back to VBA again and found a way to have it working same way as we used to have in our v8i version with MDL application.
Here's a code I have written in VBA connect edition.
Modules: PlaceDateStamp
Public Function GetDgnFilename(ByVal modelRef As ModelReference) As String GetDgnFilename = vbNullString GetDgnFilename = modelRef.DesignFile.FullName End Function Sub PlaceDateStamp() CommandState.StartPrimitive New clsStampPlacer 'calls class module named clsStampPlacer End Sub Sub UpdateDateStamp() Dim txt As TextElement Dim oELScan As New ElementScanCriteria oELScan.ExcludeAllTypes oELScan.IncludeType msdElementTypeText Dim oTextEnum As ElementEnumerator Set oTextEnum = ActiveModelReference.Scan(oELScan) Dim FilePathUpdateCounter As Integer Dim DateUpdateCounter As Integer FilePathUpdateCounter = 0 DateUpdateCounter = 0 Do While oTextEnum.MoveNext Set txt = oTextEnum.Current If Left(txt.Text, 6) = "FILE: " Then ' scans for all texts in a file that starts with first 6 string as "FILE: " Dim Path As String Dim CustomPath As String Path = GetDgnFilename(ActiveModelReference) CustomPath = "FILE: " & Path Dim text1 As String text1 = CustomPath Debug.Print text1 txt.Text = text1 'texts that has "FILE: " will be replaced by current active model design filename txt.Redraw msdDrawingModeNormal txt.Rewrite FilePathUpdateCounter = FilePathUpdateCounter + 1 End If If Left(txt.Text, 5) = "DATE:" Then ' scans for all texts in a file that starts with first 5 string as "DATE: " Dim oDate As Date Dim CustomDate As String oDate = Now() CustomDate = Format(oDate, "Medium Date") Dim oTime Dim CusomTime As String CustomTime = Format(Time, "hh:mm") Dim CustomDateTime As String CustomDateTime = "DATE: " & CustomDate & " " & CustomTime Dim text2 As String text2 = CustomDateTime Debug.Print text2 txt.Text = text2 ' texts that has "DATE: " will be replaced by current system date and time. txt.Redraw msdDrawingModeNormal txt.Rewrite DateUpdateCounter = DateUpdateCounter + 1 End If ShowCommand "Update Date Stamp" ShowPrompt "Updated Date Stamp" Loop 'Check if there are any date stamps in a file, if there are none then prompt user if they want to place Date Stamp first? Debug.Print FilePathUpdateCounter Debug.Print DateUpdateCounter If FilePathUpdateCounter = 0 Then If DateUpdateCounter = 0 Then If MsgBox("There is no Date Stamp in this Drawing." & vbNewLine & vbNewLine & "Do you want to place Date Stamp First?", vbYesNo, "Update Date Stamp") = vbYes Then 'CadInputQueue.SendKeyin "vba run [ProjectDateStamp]placedatestamp" PlaceDateStamp End If End If End If End Sub
Class Modules: clsStampPlacer
' --------------------------------------------------------------------- ' Stamp Placer class ' --------------------------------------------------------------------- Implements IPrimitiveCommandEvents ' --------------------------------------------------------------------- Private Sub IPrimitiveCommandEvents_Cleanup() End Sub '-------------------------------------------------------------------------------------------- 'DropTextNode 'Drops Text Node created in CreateStamp sub to two seperate texts before placing Date stamp. '---------------------------------------------------------------------------------------------------- Private Sub DropTextNode(ByVal TxdNd As TextNodeElement) Dim oTexts As ElementEnumerator Set oTexts = TxdNd.Drop Do While oTexts.MoveNext Dim oElement As TextElement Set oElement = oTexts.Current ActiveModelReference.AddElement oElement Loop ShowPrompt "Placed Date Stamp" End Sub '------------------------------------------------------------------------------ 'CreateStamp 'Creates a date stamp with active model file path and current system date & time '------------------------------------------------------------------------------ Private Sub CreateStamp(ByRef point As Point3d, ByVal drawMode As MsdDrawingMode) Dim Path As String Dim CustomPath As String Path = GetDgnFilename(ActiveModelReference) CustomPath = "FILE: " & Path Dim oDate As Date Dim CustomDate As String oDate = Now() CustomDate = Format(oDate, "Medium Date") ' or "Short Date" or "Long Date" or your own custom date format Dim oTime Dim CusomTime As String CustomTime = Format(Time, "hh:mm") Dim CustomDateTime As String CustomDateTime = "DATE: " & CustomDate & " " & CustomTime Dim text1, text2 As String text1 = CustomPath text2 = CustomDateTime Debug.Print text1 Debug.Print text2 ' ' ' Now Combining 2 lines of texts to one text as textnode ' ' ' ' Dim TxtNd As TextNodeElement Dim oTextEnum As ElementEnumerator Dim txt As TextElement CadInputQueue.SendKeyin "active tnj lt;CO=3;textstyle active AN18" Set TxtNd = CreateTextNodeElement1(Nothing, point, Matrix3dIdentity) TxtNd.AddTextLine text1 TxtNd.AddTextLine text2 If drawMode = msdDrawingModeNormal Then DropTextNode TxtNd 'call function DropTextNode to drop text node to two seperate texts Else TxtNd.Redraw drawMode End If End Sub ' --------------------------------------------------------------------- Private Sub IPrimitiveCommandEvents_DataPoint(point As Point3d, ByVal View As View) CreateStamp point, msdDrawingModeNormal End Sub ' --------------------------------------------------------------------- Private Sub IPrimitiveCommandEvents_Dynamics(point As Point3d, ByVal View As View, ByVal drawMode As MsdDrawingMode) CreateStamp point, drawMode End Sub ' --------------------------------------------------------------------- Private Sub IPrimitiveCommandEvents_Keyin(ByVal Keyin As String) End Sub Private Sub IPrimitiveCommandEvents_Reset() CommandState.StopDynamics CommandState.StartDefaultCommand End Sub Private Sub IPrimitiveCommandEvents_Start() CommandState.CommandName = "Date Stamp Placement" 'ShowCommand CommandState.CommandName ShowPrompt "Place Date Stamp" CommandState.StartDynamics End Sub ' ---------------------------------------------------------------------
If anyone finds it helpful, they can reuse the code.
As of now, the code is working perfectly fine for us. Only thing I'd like to add to this coding is, if I can have the scale option similar to when you are placing a cell - you have an option to scale up your cell before placing your cell. If anyone can guide me on how I can achieve that, that will be great. Thanks
Hi Jon Summers,
FYI. I updated Text Field Wikis to split Text Field links from Data Field links.
Thank you,Bob
