is it possible to check whether the cell instance from the same cell?
Hi experts,
   I have a question about the Cell instances, I have a model created with Microstation CE,   from the Cell Library, I place a Cell( for example, Cell1) three times, then i have three Cell instances in the model,
those 3 instances are from the same Cell library, so they have the same shapes(lines, arcs.. mesh....) , the question is that is there any way i can check those 3 cell instances are from the same Cell defined in the cell library?
thanks,
Rick
