[CONNECT C++] ActivateElementTemplateByPath()
It seems that using MstnElementTemplateMgr::ActivateElementTemplateByPath() does NOT update the active setting for a custom LineStyle. When I activate an Element Template that includes a custom linestyle member, when that template is activated, the linestyle is changed to 0 (zero), NOT the custom linestyle as set in the element template.
Bruce
