Is there a way to create/apply a clip volume in a view without using CadInputQueue.SendKeyin in VBA
Working on a VBA based command that needs to define a clip volume from two points from within a class that implements IPrimitiveCommandEvents.
CadInputQueue.SendKeyin terminates the execution of the command.
The steps that I'm looking to perform in the specific procedure are:
1. Apply clip volume using two points to a specific view
2. fit the view
3. Create saved view
The save view is used later in the command to create a reference attachment.
