V8i COM/VBA - Activate and dectivate reference destroys attachments object?
Hi together,
I've noticed some strange behaviour when I activate and deactivate a reference file and want to figure out if it's maybe a bug. I'am using MicroStation V8i SS3 with a master.deg with two references (ref.dgn and b.dgn). I do the following steps:
  1. Start VBA Editor and run a Test Sub ( set a watch to Application.ActiveModelReference.Attachments.Item(1) ) --> values are fine
  2. activate ref.dgn
  3. deactivate ref.dgn
  4. Run Test Sub again --> values of attachment ar no longer valid (<The object is no longer valid.>)
after step 1:
after step 4:
Do I have to refresh something? If I don't run the Sub before activating and deactivating the object is fine too.
Kind regards
Marcel
