In v8i ElemHandle::XAttributeIter got used but under CE U12 ElementHandle::XAttributeIter I get an error thats its no part of ElementHandle. In XAttributeIter.h ElementHandle::XAttributeIter is mentioned but no implementation or do I overlook something?
Hi Jean-Pierre,
Jean-Pierre Hundhausen said:ElementHandle::XAttributeIter is mentioned
it seems documentation is not correct at this point.
Jean-Pierre Hundhausen said:or do I overlook something?
I guess (but based on documentation only) you should use XAttributeCollection to obtain all XAtrtibutes and to iterate them.
With regards,
Jan
Jean-Pierre Hundhausen said:In v8i ElemHandle::XAttributeIter
As Jan wrote, CONNECT has the XAttributeCollection that you construct from an ElementRef.
ElementRef
XAttributeCollection provides the begin() and end() methods like any of the C++ standard collection classes...
begin()
end()
XAttributeCollection attributes (elemRef); for (auto& entry = attributes.begin(); entry != attributes.end(); ++entry) { ... do something with attribute }
Many interfaces in the MicroStationAPI either implement the C++ collection classes or emulate the essential functionality for enumeration.
A good example is the Bentley vector template bvector<>. It is a C++ standard vector template class.
bvector<>
It has certain characteristics that make it safe to use in your apps. when working with MicroStation built-in functions. As far as you — the programmer — are concerned, it behaves just like a std::vector<>. There's more info in this article.
Answer Verified By: Jean-Pierre Hundhausen
