Hi Experts,
I meet a issue where i need to read the ECInstance's properties, i can get the property name and values, but for some properties, i can't get the unit informaiton, what i need to get is the displayed value
exactly with that show in the Microstation's property panel.
my C# code to read the properties as below,
IEnumerable<IECProperty> properties = instance.ClassDefinition.Properties(true); foreach (IECProperty prop in properties) { IECPropertyValue propValue = instance.GetPropertyValue(prop.Name); IECProperty valuePro = propValue.Property; if (propValue != null) { string strCategory = ECInstanceUtil.GetPropertyInformation(prop); string type = prop.Type.Name.ToLower(); InstancProperty instanceProp = new InstancProperty(); instanceProp.Name = prop.Name; instanceProp.Type = type; instanceProp.DisplayLabel = prop.DisplayLabel; instanceProp.Description = prop.Description; instanceProp.Category = strCategory; string value = string.Empty; value = propValue.StringValue; } }
for the Three properties higlighed in the above screen shot, I just get the value without any unit informaiton, my question is how i can get the displayed value as show in Microstation's property panel?
I have read other thread in the forums such as https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/140064/connect-c-how-to-read-ec-units/424234#424234
but i did not get an answer for now, my model is attached,
/cfs-file/__key/communityserver-discussions-components-files/343173/_0A4E6568A267BD7E346C3A679263346C_-v1.dgn
thanks,
Rick
what i get is as below,
you can see the unit is missing.
Rick,
please! edit your post and use Insert > Insert code tool to include the code snippet to your post. To share code as plain text is just annoying and makes readability quite complicated.
TIA Jan
Hi Rick,
Rick cheng said:I just get the value without any unit informaiton
I assume that EC property is defined using Unit custom attribute, so this information is not included in EC property value.
Rick cheng said:but i did not get an answer for now
My experience is limited, I recommend to search for discussion about EC formatter, it has been discussed several times.
I also recommend to study ECObjects API (e.g. IECTypeAdapter.ConvertToString method), but I see you use quite old MicroStation version and I am not sure whether ECObjects documentation was included in SDK at this time.
With regards,
Jan
ok, i will update it. thanks
Hello Mr. Cheng,
I assume you can read Chinese and you can refer below post to get what you want:
https://communities.bentley.com/communities/other_communities/chinafirst/f/microstation-projectwise/159071/ce-c/474446#474446
yes, i can read chinese, and thanks for the reply, i will follow the refered link.
Hi Fu,
I check the link you share, i think it helps. but my question here is that is there any C# api for the below code,
IDgnECTypeAdapterR typeAdapter = IDgnECTypeAdapter::GetForProperty(*ecProp); IDgnECTypeAdapterContextPtr typeContext = IDgnECTypeAdapterContext::Create(*ecProp, *elemInst, ecProp->GetName().GetWCharCP()); typeAdapter.ConvertToString(wStr, ecVal, *typeContext);
i did not found the corresponding C# api for type adapter, do u know is there any C# api i can use. while i did found the C++ api as list in the above code.
Seems not. DgnECTypeAdapter only exists in C++ API.
ok, got it, thanks for the reply.
i will try it with C++ api.
