How is it possible to run a macro in another .mvba from the Autorun
I have added some commands: in the Autorun
CadInputQueue.SendCommand "View Off All" 'Turn off all views CadInputQueue.SendCommand "View On 1" 'Turn View 1 on CadInputQueue.SendCommand "Window Tile" 'Resize View 1 to fit screen CadInputQueue.SendCommand "Fit All" 'Start Fit All command CadInputQueue.SendCommand "Selview 1" 'Apply to View 1
These all work, what I wanted to add was a Macro from Name.mvba and I know it is Module6.SetDefaults
I can run the macro from the key-in command vba run SetDefaults and it works fine, but I was hoping to add it to the autorun
and eliminate extra commands
Richard Phillips said:How is it possible to run a macro in another .mvba
Use CadInputQueue.SendKeyin to replicate what you would type into MicroStation's key-in dialog...
Dim keyIn As String keyIn = "vba run [Name]Module6.SetDefaults" CadInputQueue.SendKeyin keyIn
Answer Verified By: Richard Phillips
Jon, thank you for the reply
Is this where I add the above statements ?
Really was uncertain where to place the answer you were nice enough to answer. Perhaps I should have name(no ext) and the
statement above
Dim keyIn As String keyIn = "vba run [Name]Module6.SetDefaults" CadInputQueue.SendKeyin keyIn Oh, Jon I went ahead and put just RUN VBA RJBP(Which is the name)Module6.setdefaults"i HAD ADDED THE Message line and it put Ran AutoRun.mvba but nothing fromModuleTried Dim KeyIn As String KeyIn = "VBA RUN [RJBP]Module6.SetSDFpreferences" CadInputQueue.SendKeyin KeyInI even tried VBA RUN RJBP.Module6.SetSDFpreferences" Each time am getting error message VBA INTERFACE error:I also move the commands below yours:When you can spare me some mover of your valuable time, I would appreciate or anyone else who wants to come in
Version: MicroStation V8i SS 10
RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
Jon It is working I noticed the computer was referring to my RJBP.MVBA as default when I sent the last picture
went back and change [name] to [default] it came up with DGNSET loaded checked the settings>Design File Settings
and they were all done, so appreciate so much for the assistance. Email me sometime, I put up a question on you business page
trying to get a price on something. My email (this would not be a company purchase) I will have to personally pay you
any way rjbphillipsiii1945@gmail.com I hope this is not a violation just asking someone to contact you? If it is very sorry.
