I drew a CellElement, as shown in the figure,
I want to turn it into another shape. This shape is an element created by the CreateShapeElement1 method in the VBA document.
Is there any way to realize it, any suggestions would be grateful?
Hello Alisa,
I am not sure what your problem is in detail.
C# in V8 is just a cover to VBA, so you could use every function from VBA. Or are you asking how to build a standard modification function (locate - > read - > modify|replace - > rewrite)?
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
Hi Alisa,
I agree with Volker that it's not clear what your are asking about. In the fisrt sentence you mentioned CellElement, but in second one you use "shape". Also the pictures seem to be completely different: First one is quite complex, second is just one element (shape?).
If you need to change existing cell, the most simple way is to create a new one with new parameters. This approach has some disadvantages (e.g. existing elements are deleted and new element have new element id), which can be problem sometimes.
With regards,
Jan
Hi Alisa LI,
As Jan and Volker mention, "the end goal" may not be apparent. Given picture 1 and 2, I presume you may want to "Pattern" or "Hatch" the 2nd shape shown with the 1st cell. If this is the case, maybe this will help.
NOTE: You can use search for any search term using: a.) wildcards (e.g. *needtofindsomething*), b.) quotes (e.g. "need to find something", and c.) boolean operators: AND, OR, NEAR, and NOT (e.g. Need AND to AND find AND something)
I think the code snip provided in the "SetPattern" help topic may help if you are asking how to pattern an element using a pattern cell.
HTH,Bob
Thanks for your answer, I should not describe my problem clearly. I would like to ask if the MTAN VBA method provides an interface to the method in the figure.
I want to use this methodto achieve my purpose,
but I didn't find it in VBA.
Looking forward to your answer
Alisa LI said:I would like to ask if the MTAN VBA
What is MTAN VBA? Do you mean MicroStation? Usually MStn abbreviation is used, nothing else.
Alisa LI said:VBA method provides an interface to the method in the figure.
It seems you are asking about something completely different than originally. I do not see any link between 3D Boolean tools you ask about now and patterned cells shared in the past. But anyway..
Alisa LI said:I want to use this methodto achieve my purpose,
VBA provides API to MicroStation kernel, not to MicroStation tools (that are implemented using the same API as MicroStation publishes externally). So when you want use tools, you usually have to work with them through key-ins.
You do not specify what MicroStation version do you use. Please read and follow best practices and specify the used version. VBA has provided only limited 3D API and it has changed in different V8i version. Because you mentioned V8i without any specification and there are many versions of V8i, it's not possible to guess whether your version provides at least some 3D API (e.g. V8i SS3 / SS4 / SS10) or not (original V8i versions).
BTW Please follow best practices also how subject should be formatted. To use not standard format [<product> <version> <language>] but separate different style brackets maybe looks interesting, but does not offer any benefit like better readability.
Alisa LI said:Looking forward to your answer
Specify what MicroStation version do you use.
Check your MicroStation VBA documentation for SmartSolid object and related methods. I see methods like SolidIntersect, SolidSubtract and SolidUnion in V8i SS4 VBA API.
When the methods provide not enough functionality, you can call MDL functions through P/Invoke from C# or for more complex code, you can you C++/CLI as a bridge between native C/C++ API and managed world.
Answer Verified By: Alisa LI
Jan Šlegr said:you can call MDL functions through P/Invoice
P/Invoice? Must be Microsoft's new billing method. There must be a P/GiveMeYourCreditCardDetails to complement that.
Hmmm ... it looks like I slept still when I wrote the answer ;-) The type is corrected now.
Alisa LI said:I drew a CellElement
Alisa LI said:I want to turn it into another shape
As others have commented, your goal is not clear. Nobody understands what you want to achieve. However, we all use MicroStation.
Why not post a DGN file that includes example models? Show us...
Your post and reply appear to be asking about (2) different types of issues. Here are a couple things that may help:
As you may be new and learning MicroStation APIs in V8 using C#, we have found it best to perform as much coding directly in VBA (to be loaded and run) using MicroStation Key-ins from C#/.NET wherever possible. Doing so makes it much easier to isolate and test issue if/when they go wrong; easier to debug and improved performance.
With the Bentley Communities you may also want to leverage using the fairly powerful Communities search features. This can help you explore e.g. (different words of interest - search terms) and see if someone else has asked and possibly resolved each issue w/o having to create a new post/question. So, for instance this may be how I would try to find information based on your most recent question and search for: e.g. VBA AND intersect AND solid.
