I am trying to automate several different processes through Keyins and VBA. I am not a programmer, just trying to make things work through Keyins and recording VBA macros. I have manged to edit some of the macros to get things done. The problem we keep running into is how do automate the left click in the background to accept a command?
For instance, If through a keyin I select a cell and want to adjust the scale to the active scale, I have to left click in the background to accept the change. When I tried recording the process to create a VBA macro it does not show us. There must be a simple solution.
Any help is greatly appreciated.
Thank you,
Robert
V8i (SELECT series 3) 08.11.09.459
btusini said:How do we automate the left click in the background to accept a command?
Something like this? Usually the location of the confirming data point is not relevant, so we pass 0,0,0...
CadInputQueue.SendDataPoint Point3dZero
Answer Verified By: Robert Hook
Jon,
Thank you for your response. Found xy=0,0 works as well in keyin. Sometimes its the smallest thing...ugh :).
Bob
