[U12 C++] AccudDraw.SetContext() and AccuDrawFlags
Can someone provide a "mapping" between the parameters of AccuDraw.SetContext() and the AccuDrawFlags? The example only seems to use "ACCUDRAW_SetXAxis". For example, If I wish to use ACCUDRAW_UpdateRotation, which parameter(s) of AccuDraw.SetConext() should I use? The header file provides no clues.....
enum AccuDrawFlags
    ACCUDRAW_SetModePolar       = (1),
    ACCUDRAW_SetModeRect        = (1<<1),
    ACCUDRAW_SetOrigin          = (1<<2),
    ACCUDRAW_FixedOrigin        = (1<<3),
    ACCUDRAW_SetRMatrix         = (1<<4),
    ACCUDRAW_SetXAxis           = (1<<5),
    ACCUDRAW_SetNormal          = (1<<6),
    ACCUDRAW_SetDistance        = (1<<7),
    ACCUDRAW_LockDistance       = (1<<8),
    ACCUDRAW_Lock_X             = (1<<9),
    ACCUDRAW_Lock_Y             = (1<<10),
    ACCUDRAW_Lock_Z             = (1<<11),
    ACCUDRAW_Disable            = (1<<12),
    ACCUDRAW_Set3dMatrix        = (1<<13),
    ACCUDRAW_OrientDefault      = (1<<14),
    ACCUDRAW_SetFocus           = (1<<15),
    ACCUDRAW_Delay              = (1<<16),
    ACCUDRAW_OrientACS          = (1<<17),
    ACCUDRAW_SetXAxis2          = (1<<18),
    ACCUDRAW_LockAngle          = (1<<19),
    ACCUDRAW_AllowStartInLocate = (1<<20),
    ACCUDRAW_AlwaysSetOrigin    = ((1<<21)|ACCUDRAW_SetOrigin),
    ACCUDRAW_RedrawCompass      = (1<<22),
    ACCUDRAW_UpdateRotation     = (1<<23),
  • Here's an implementation for a helper class to avoid having to call SetContext directly. This class doesn't actually exist, it was adapted from imodeljs and I don't promise it compiles. I've posted it as it demonstrates how to properly call SetContext and what the useful AccuDrawFlags are. Usage:
    AccuDrawHintBuilderPtr hints = AccuDrawHintBuilder::Create();
    hints->SetOrigin(..);
    hints->SetRotation(..);
    hints->SendHints();
    * AccuDrawHintBuilder is a DgnTool helper class that facilitates AccuDraw interaction.
    * The tool does not directly change the current AccuDraw state; the tool's job is merely
    * to supply "hints" to AccuDraw regarding it's preferred AccuDraw configuration for the
    * current tool state. User settings such as "Context Sensitivity" and "Floating Origin"
    * affect how/which hints get applied.
    * @bsiclass
    struct AccuDrawHintBuilder : RefCountedBase
    private:
        bool        m_setOrigin:1;
        bool        m_setOriginFixed:1;
        bool        m_setOriginAlways:1;
        bool        m_setRotation:1;
        bool        m_setXAxis:1;
        bool        m_setNormal:1;
        bool        m_setDistance:1;
        bool        m_setAngle:1;
        bool        m_setModePolar:1;
        bool        m_setModeRectangular:1;
        bool        m_setLockDistance:1;
        bool        m_setLockAngle:1;
        bool        m_setLockX:1;
        bool        m_setLockY:1;
        bool        m_setLockZ:1;
        DPoint3d    m_origin;
        DVec3d      m_axis;
        RotMatrix   m_rMatrix;
        double      m_distance;
        double      m_angle;
    public:
        AccuDrawHintBuilder();
        //! Create an instance of an AccuDrawHintBuilder for the purpose of tool interaction with AccuDraw.
        //! @return A reference counted pointer to an AccuDrawHintBuilder.
        static AccuDrawHintBuilderPtr Create();
        void SetOrigin(DPoint3dCR); //!< Specify location for the compass origin.
        void SetRotation(RotMatrixCR); //!< Fully specify compass orientation. Tools should take care to not make AccuDraw's Z perpendicular to the view's Z.
        void SetXAxis(DVec3dCR); //!< Specify compass X axis direction taking the current AccuDraw rotation into account in computing Y and Z axes.
        void SetNormal(DVec3dCR); //!< Specify compass Z axis direction taking the current AccuDraw rotation into account in computing X and Y axes.
        void SetModePolar(); //!< Change compass to polar mode.
        void SetModeRectangular(); //!< Change compass to rectangular mode.
        void SetDistance(double); //!< Specify polar mode distance (in uors).
        void SetAngle(double); //!< Specify polar mode angle (in radians).
        void SetOriginFixed(); //!< Specify that compass remain at a fixed location for the current tool and not follow subsequent data points.
        void SetOriginAlways(); //!< Specify that "Floating Origin" setting not be honored which would normally cause the SetOrigin hint to be ignored.
        void SetLockDistance(); //!< Specify that polar mode distance is locked. Locks are cleared on next data button or by user interaction.
        void SetLockAngle(); //!< Specify that polar mode angle is locked. Locks are cleared on next data button or by user interaction.
        void SetLockX(); //!< Specify that rectangular mode X delta is locked. Locks are cleared on next data button or by user interaction.
        void SetLockY(); //!< Specify that rectangular mode Y delta is locked. Locks are cleared on next data button or by user interaction.
        void SetLockZ(); //!< Specify that rectangular mode Z delta is locked. Locks are cleared on next data button or by user interaction.
        BentleyStatus SendHints(bool activate = true); //!< Calls AccuDraw::SetContext using the current builder state.
    * @bsimethod
    AccuDrawHintBuilderPtr AccuDrawHintBuilder::Create() {return new AccuDrawHintBuilder();}
    * @bsimethod
    AccuDrawHintBuilder::AccuDrawHintBuilder()
        m_setOrigin = m_setOriginFixed = m_setOriginAlways =
        m_setRotation = m_setXAxis = m_setNormal =
        m_setDistance = m_setAngle = m_setModePolar = m_setModeRectangular =
        m_setLockDistance = m_setLockAngle = m_setLockX = m_setLockY = m_setLockZ = false;
    * @bsimethod
    void AccuDrawHintBuilder::SetOrigin(DPoint3dCR origin) {m_origin = origin; m_setOrigin = true;}
    void AccuDrawHintBuilder::SetRotation(RotMatrixCR rMatrix) {m_rMatrix = rMatrix; m_setRotation = true; m_setXAxis = m_setNormal = false;}
    void AccuDrawHintBuilder::SetXAxis(DVec3dCR xAxis) {m_axis = xAxis; m_setXAxis = true; m_setRotation = m_setNormal = false;}
    void AccuDrawHintBuilder::SetNormal(DVec3dCR normal) {m_axis = normal; m_setNormal = true; m_setRotation = m_setXAxis = false;}
    void AccuDrawHintBuilder::SetModePolar() {m_setModePolar = true; m_setModeRectangular = false;}
    void AccuDrawHintBuilder::SetModeRectangular() {m_setModeRectangular = true; m_setModePolar = false;}
    void AccuDrawHintBuilder::SetDistance(double distance) {m_distance = distance; m_setDistance = true;}
    void AccuDrawHintBuilder::SetAngle(double angle) {m_angle = angle; m_setAngle = true;}
    void AccuDrawHintBuilder::SetOriginFixed() {m_setOriginFixed = true;}
    void AccuDrawHintBuilder::SetOriginAlways() {m_setOriginAlways = true;}
    void AccuDrawHintBuilder::SetLockDistance() {m_setLockDistance = true;}
    void AccuDrawHintBuilder::SetLockAngle() {m_setLockAngle = true;}
    void AccuDrawHintBuilder::SetLockX() {m_setLockX = true;}
    void AccuDrawHintBuilder::SetLockY() {m_setLockY = true;}
    void AccuDrawHintBuilder::SetLockZ() {m_setLockZ = true;}
    * @bsimethod
    BentleyStatus AccuDrawHintBuilder::SendHints(bool activate)
        uint32_t    flags = 0;
        if (m_setOrigin)
            flags |= ACCUDRAW_SetOrigin;
        if (m_setOriginFixed)
            flags |= ACCUDRAW_FixedOrigin;
        if (m_setOriginAlways)
            flags |= ACCUDRAW_AlwaysSetOrigin;
        if (m_setRotation)
            flags |= ACCUDRAW_SetRMatrix;
        if (m_setXAxis)
            flags |= ACCUDRAW_SetXAxis;
        if (m_setNormal)
            flags |= ACCUDRAW_SetNormal;
        if (m_setModePolar)
            flags |= ACCUDRAW_SetModePolar;
        if (m_setModeRectangular)
            flags |= ACCUDRAW_SetModeRect;
        if (m_setLockDistance)
            flags |= ACCUDRAW_LockDistance;
        if (m_setLockAngle)
            flags |= ACCUDRAW_LockAngle;
        if (m_setLockX)
            flags |= ACCUDRAW_Lock_X;
        if (m_setLockY)
            flags |= ACCUDRAW_Lock_Y;
        if (m_setLockZ)
            flags |= ACCUDRAW_Lock_Z;
        if (SUCCESS != AccuDraw::GetInstance().SetContext((AccuDrawFlags) flags, &m_origin, m_setRotation ? (DVec3dCP) &m_rMatrix : &m_axis, NULL, m_setDistance ? &m_distance : nullptr, m_setAngle ? &m_angle : nullptr))
            return ERROR; // Not enabed for this session...
        if (activate)
            AccuDraw::GetInstance().Activate(); // If not already enabled (ex. dynamics not started) most/all callers would want to enable it now (optional activate arg provided just in case)...
        return SUCCESS;
Reply Children
