These two lines of code build OK but cause an Internal Error: Access Violation at runtime …
PickListLibrary lib; PickListLibrary::GetPickListLibFromDgn (ISessionMgr::GetActiveDgnFile (), lib);
struct PickListLibrary : public RefCountedBase tells us that PickListLibrary is a reference-counted class. I would expect there to be a static public Create() method to get a smart pointer (PickListLibraryPtr). However, there's no MakeAbstract() or other means in the class declaration to make PickListLibrary abstract.
PickListLibrary
PickListLibraryPtr)
MakeAbstract()
Non-intuitively, the following does work...
PickListLibraryP lib { PickListLibrary::CreatePickListLibrary () }; PickListLibrary::GetPickListLibFromDgn (ISessionMgr::GetActiveDgnFile (), *lib); // Use lib->Xxx() // delete lib?
But what do I have: a normal pointer or a smart pointer? That is, should I delete lib or not?
delete lib
Hi Jon,
Thank you for reporting the issue. Could you please send me an example for the first code? I have used it in many places while I haven't met the runtime error which you got.
Colin
Colin Wang said: Could you please send me an example for the first code?
Here's a modified version of your PickList NativeExample project. There's an additional command INSTANCE that tests static and dynamic creation of a PickListLibrary. Dynamic allocation works; static allocation fails at runtime.
NativeExampleLASolutions.zip
Thank you, Jon. We are working on it.
The change will be released in Update 13.
There won’t be code like: PickListLibrary lib; //This line will cause compiling error
or
It must be: PickListLibraryPtr pickListLib = PickListLibrary::CreatePickListLibrary();
Thanks & Regards,
Answer Verified By: Jon Summers
