PickListLibrary::PickListExistsInDgn()
PickListLibrary::CanFindPickListByNameInDgn()
Hi Jon Summers,
Other than having parameters listed in different order, PickListExistsInDgn() can likely be set to private/hidden (or removed) to avoid confusion since the public PickList API is available and no longer in Early Access Preview state. I will check with the developer to see if this is appropriate along with any others that may have been superseded.
Thank you and HTH,Bob
[20190603j-RH: Verified WorkItem 1028925]
Hi Jon,
Thank you very much for the reporting. I'm looking into it and will fix the confusion.
Colin
These two methods are same. We'll remove CanFindPickListByNameInDgn in Update 13.
Thanks & Regards,
Answer Verified By: Jon Summers
