Just wanted to make a post to hopefully help some people.
I have created a guide linked below, that walks you through how to set up a visual studio project to be used as an Addin within MicroStation.
Creating MicroStation Addins in C# with Visual Studio - A Step by Step Guide This document contains a detailed, step by step guide in creating C# WPF Addins for MicroStation and ORD. PDF The guide walks you through the following topics Downloading the SDK Using the Developers… Last edited over 3 years ago in Ohio DOT & Consultants > OhioDOT - Wikis 2 comments
hopefully it will save people from the struggles i went through to figure out how to set one up.
Thank you.
I believe there is an entire forum set up for discussion of MicroStation Programming where this would be most appropriate and welcome.
MaryB
John Drsek said:I have created a guide
Thanks for posting!
thanks, moved
Thank you for sharing
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
Thank you for posting this!
I also have written a series of Learning XXX step by step as below.
https://communities.bentley.com/communities/other_communities/bdn_other_communities/w/chinabdn-wiki
Due to my not good English, only one article has English version, others are in Chinese. But I think Google translator can do better than me.
Hi Yongan,
Would you be able to get your guides translated to English. They would be very valuable for us English speakers.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
I am not a native English speaker. I believe my English is worse than Google translator.
Perhaps try starting with this and if you have any specific queries then ask a question. If the image below isn't clear, right-click it and open in a new tab.
Mark,
why don't you give my guide a look. instead of trying to translate one. and then come back with questions.
