I have a working IF-THEN-ELSE, could I request a little help on the messages in the msgbox I have read and read thought they wanted
ASCII Chr 13 in the help file I saw (Chr(*)) thevalue for ascii 13 which when I use Alt numeric 13 I get the question Mark I am attaching the working code and a few ways I tried the Message to get more in the box. I have learned about the 0 - 5 and the options it gives.
The first code works, not message box like I want with 3 lines. Then next section of code is what I have tried and failed on
Loosing a lot of time if I could get someone in the know to help. Tried from 12:18am to 3:47am finally got the IF then working
but could never get the message Box.
Private Sub SeletRoutine() ' 050419 - This is working need to know how to enter multi-Line Message____________________________________RJB Dim Message, Title, Default, ValSel ShowStatus " " Title = "Enter Selection to RUN" ' Set title. 060419 Modified_______RJB Message = "Enter a value between 1 and 3" ' Set prompt. 'Message = "Selection 2 Set View Attributes " ' Set prompt. Default = "1" ' Set default. ValSel = InputBox(Message, Title, , , , "DEMO.HLP", 10) ' Display message, title, and default value. If ValSel = 1 Then 'MsgBox "User pressed Yes!" ShowStatus " 1 was selected" ElseIf ValSel = 2 Then 'MsgBox "User Pressed No!" CadInputQueue.SendKeyin "Macro SetDesignFileView" ShowStatus "View Set w=985 H=723" ElseIf ValSel = 3 Then 'MsgBox "User Pressed No!" ShowStatus "3 was selected" Else 'MsgBox "User Pressed Cancel!" ShowStatus "Cancel was selected" End If End Sub
Private Sub Selections() ' 060519 - Trying again Dim Message, Title, Default, ValSel Title = "InputBox Select Feature: 'Set title." 'Message = "Enter 1 for yellow Magenta ? Enter 2 for green magenta.? Enter 3 for Cyan Magenta?" 'Message = "Enter a value between 1 and 3?", 2 "Second row of questions" ' Set prompt. this failed Message = "Enter 1 for yellow Magenta ?',(Chr(?)), "Enter 2 for green magenta.?",(chr(?)), "Enter 3 for Cyan Magenta?" THE ABOVE SECTION IS WHERE I WAS TRYING TO SET THE MESSAGE BOX INFORMATION Above code is another working macro. Did not want to mess it up so started another with different name. Trying to figure out a multi-line message box
Hi Richard,
I appreciate VBA programming is something you are only just trying to get to grips with, I'm far from being a VBA expert though I too have received plenty of help in the past from Jon and Jan who have helped me reach a level of competence where I can now tackle many tasks on my own. I will assist you where I can however it's a bit hard to understand what your actual aim is. It would be beneficial if you explain the goal of the code and what the user is expected to experience in order to help you reach a solution quicker.
The sketch is fine. Something I have done previously when starting on a complex program I wrote was to draw out a flow-chart diagram showing the user interface and what happened whenever a user pressed a certain button or entered a certain value. It can help as a guide for how you need to lay out your code by breaking it down into individual tasks.
As for the code samples, you have provided 2 procedures called SeletRoutine (spelling mistake?) and Selections yet they do not appear to be related as one is not called from another which is what I would have initially expected i.e. it sounds like you want a dialog box to appear (called a userform), the user is then required to enter a number and then something to happen afterwards. Please be clear if that is or not the intention.
As for the code you have provided, some observations:
Dim Variable_One As String
If you have a variable which will store a decimal number
Dim Variable_Two As Long
If you have a variable which will store a whole number number
Dim Variable_Three As Integeretc...
Thank You #1 I got the code from Goggle search and attempted to modify for what I was trying to learn. the code I will stick with the one that at least works
SelectRoutine I messed up on the word Select yes. Ok working from that
I am going to post 2 pictures of the MsgBox close to what I want the achieve.
the drawing was to show what I was trying to get the Message box to do and could not.
Where it says Enter a value is where I was hoping to have the
Text example in the Sketch
Color Green-Magenta "button" [1]
Color Cyan-Megenta "second button" [2]
Color Blue-Red "then a 3rd button" [3]
and if possible a Cancel Button [Cancel]
looking above I do not want the text in " " just the color selections
and the Cancel button w/no explanation text
Is another example w/Cancel I was hoping to have 4 total selections
"Button1" [1]
"Button2"[2] etc with the Cancel at the bottom. Do not really care for the long open box to put numbers in but liveable if I could get the information above the long open box for the 1, 2 or 3 plus the Cancel. Anything like that
is fine. the two macro's were to show the different Msgbox's
Lets focus on this and will work out the rest because it does work Example
i can put a 1, 2 or 3 and it will go to them. So if you know how to put the information on the screen (again this is not going to be used as it is )
trying to learn and it proves it works via the ShowStatus
I was looking at a Menu command but do not know enough to figure out how it will do a similar task. Again @ 74 June 12th I do not have the time to read a lot of books. I used Jon Summers suggestion and goggle it . It seems I cannot ask the question properly to find the answer on this part the buttons and Text information.
Version: MicroStation V8i SS 10
RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
I am glad your post have evolved to better format, with pictures and properly formatted code they look much better :-)
But still ... please do not mix several different questions about different issues with opinion and thoughts! It makes the question to be hardly answered. One question (issue) per post! What is your real question/issue in this discussion? Is it "problem with CHr(13)" or different versions of my code do (not) work" or something else, hidden in your text?
Why to don't ask in very simple way "Is it possible to display multi-line text in VBA MessageBox?" (as Barry Lothian mentioned already)?
Regarding to your code, I have several comments, similar to what Barry Lothian wrote:
Result can be:
Option Explicit ... Private Sub <routine name> Dim BoxTitle as String Title = "..." Dim BoxMessage as String Message = "..." Dim MessageBoxResult as String MessageBoxResult = InputBox(... End Sub
Other recommendations are:
Result can be like this ... I think the structure and functionality is clear and well divided into own code chunk. Consequently it means every single piece of the code (sub or function) can be easily tested for its exactly defined functionality.
' Option Explicit defined somewhere on top of macro Public Sub ShowMessageBox() Dim BoxTitle As String: BoxTitle = "Enter Selection to RUN" Dim BoxText As String: BoxText = GetBoxText Dim MessageBoxResult As String MessageBoxResult = InputBox(BoxText, BoxTitle, "") Select Case MessageBoxResult Case "1" ProcessBoxSelection1 Case "2" ProcessBoxSelection2 Case "3" ProcessBoxSelection3 Case Else ProcessIncorrectBoxSelection End Select End Sub Private Function GetBoxText() As String GetBoxText = "Enter a value between 1 and 3:" & vbCrLf GetBoxText = GetBoxText & "Selection 1 - Green-Magenta" & vbCrLf GetBoxText = GetBoxText & "Selection 2 - Cyan-Magenta" & vbCrLf GetBoxText = GetBoxText & "Selection 3 - Yellow-Red" End Function Private Sub ProcessBoxSelection1() ShowStatus "Value 1 was entered" End Sub Private Sub ProcessBoxSelection2() ShowStatus "Value 2 was entered" End Sub Private Sub ProcessBoxSelection3() ShowStatus "Value 3 was entered" End Sub Private Sub ProcessIncorrectBoxSelection() ShowStatus "Incorrect value was entered" End Sub
With regards,
Jan
Richard Phillips said:Again @ 74 June 12th I do not have the time to read a lot of books.
Which means you are deserved to fail every time :-(
And it's nothing that you can be proud of.
Cumulated sum of time required to solve issues and errors done because there is no strong knowledge foundation (which can be acquired reading just by one or two books at max) is always several times bigger than time required to read this book.
