IDgnECInstance
I can write code like this to display the value of a named property of an IDgnECInstance...
int i = 0; foreach (IDgnECInstance instance in instances) { s.Clear(); s.AppendFormat("Instance [{0}] ID {1}", ++i, instance["ID"].StringValue); MessageCenter.Instance.ShowMessage(MessageType.Debug, s.ToString(), s.ToString(), MessageAlert.None); }
If I don't know the name (a.k.a. access string) of a property, can I get an iterable list of properties? I can't use an integer indexer (instance[0].StringValue) because it's not part of the IDgnECInstance interface. What I'm asking about is a possibly fictional interface like this...
int nProperties = instance.GetPropertyCount (); for (int i = 0; i != nProperties; ++i) { Property prop = instance.Properties [i]; }
Documentation about IDgnECInstance is terse. It inherits from IECInstance, which has no documentation whatsoever.
IECInstance
An IECInstance is-a IEnumerable<IECPropertyValue>, so yes you can iterate it.
Answer Verified By: Jon Summers
I've published an example Viz Studio project Item Instance Collector. Your advice helped me to write that project!
