There are several DgnDocument.Create static methods...
DgnDocument.Create
CreateForEmbeddedFile
CreateForLocalFile
CreateForNewFile
CreateFromFileName
CreateFromMoniker
The MstnPlatformNet help is, as usual, terse. What do those all mean?
To create a DgnDocument for a DGN file on my server, which of those should I use?
DgnDocument
Hi Jon,
This is documented in the DgnPlatformNet.chm file. I would use CreateFromFileName.
Paul
Paul Chater said:This is documented in the DgnPlatformNet.chm file
It's also documented, incompletely, in the MstnPlatformNet.chm file...
MstnPlatformNet.chm
So my question morphs into another: "Why aren't the MstnPlatformNet and the DgnPlatformNet help files synchronised? Why are there two files? MstnPlatformNet contains the same topics as DgnPlatformNet.
