[CONNECT C#] Show Element Property Selection Dialog
Just wondering if the sdk has available the ability to show the select property dialog that has the properties of a selected element shown and allow the user to select a property an return that selection.
Basically what you see when you add a field to text to show a element property.
thanks
JD
