[CONNECT C++] Setting up C++ Visual Studio Project problems
hoping someone might be able to help me out. I have been writing addins in C#, but now im trying to start out with using c++/Cli for some wrappers. but I'm getting errors from the start...
here are the steps I took to create a c++/Cli  class project.
1.open VS2015 and create new c++/CLI class project,
2. close and open the sln file from MicroStation SDK command prompt
3. add include location to properties.
4. add lib location to properties
5. then all I did was start to add using statements to my header file. I only added #include<Mstn\MdlApi\MdlApi.h>
once I added that I got 2 errors.
cannot open source file "_config-eccp.h"
and #error directive: Data Alignment must be defined in basedefs.h.
im a newbie what it comes to c++...
