Could anyone offer any help with how to do this? I see a TextFieldDictionary in the API. but not really sure how to implement this.
what im trying to do is for a given text element get all the text fields that are linked to a property of a item type. as well as change what property that field is linked to.
I used the code from Yongan.Fu in post https://communities.bentley.com/communities/other_communities/chinafirst/f/microstation-projectwise/180135/msce-c-textblock to create a text field but that's pretty much the only example of textfields I could find.
JD
Hi John Drsek and Jon Summers,
I received an update that a developer in this area will provide a review and update on this as soon as possible that I will pass along once available.
Thank you,Bob
Robert Hook said:I received an update that a developer in this area will provide a review and update on this as soon as possible that I will pass along once available.
Thanks! :-)
Because there is not a workaround using EC API available (I was not able to find a way how to interpret TextFields using EC), to publish proper API is quite crucial.
Jan
