[CONNECT C++] Field validation issue
The maximum LevelCode value is 4294967295. How to add field validation in dialog so it allows values from 0-4294967295?
For example using MDL basic Dialog:
DialogBoxRsc DIALOGID_Basic =
    DIALOGATTR_DEFAULT | DIALOGATTR_SINKABLE,
    25*XC, 7*YC,
    NOHELP, MHELP, HOOKDIALOGID_Basic, NOPARENTID,
    TXT_BasicDialogBox,
{{X1,GENY(1),XW,0}, LEVELID,	      LEVELID_Basic, ON, 0, "0", "4294967295"},
{{X1,GENY(2),XW,0}, OptionButton, OPTIONBUTTONID_Basic, ON, 0, "", ""},
{{X2,GENY(4),BTN_WIDTH,0}, PushButton, PUSHBUTTONID_OModal, ON, 0,"",""},
It only works with values 0-2147483647 but if set 2³² as maximum then it allows only negative values and shows message "Field must be between 0 & 4294967295".
LevelID decalared as unsigned int.
Parents Reply Children
