[CE U13 C#] Bug? Element selected but not highlighted
Hi experts,
I have a DgnFile linked to other DgnFiles.
I'm trying to programmatically select an item inside a referenced Dgnfile.
It seems that the element is selected (I can see it in “Selection Set number of elements”), but visually the element is not highlighted.
Even if I try to manually force the Hilite on that element, nothing happens.
The same procedure works perfectly on the elements in the main DgnFile.
Here some example code:
class ElementHighlighter : IDisposable
        ElementAgenda elementAgenda_;
        ElementAgendaDisplayable elementAgendaDisplayable_;
        DgnModelRef _dgnModelRef;
        public void SetDgnModel(DgnModelRef dgnModelRef)
            _dgnModelRef = dgnModelRef;
        public enum HighlightCriteria
            SingleHighlight,
            MultipleHighlight,
        private HighlightCriteria highlightCriteria_;
        public ElementHighlighter()
            elementAgenda_ = new ElementAgenda();
            elementAgendaDisplayable_ = new ElementAgendaDisplayable();
            SelectionSetManager.BuildAgenda(ref elementAgenda_);
            highlightCriteria_ = HighlightCriteria.SingleHighlight;
        public HighlightCriteria Criteria { get { return highlightCriteria_; } set { highlightCriteria_ = value; } }
        public void Empty()
            SelectionSetManager.EmptyAll();
            elementAgendaDisplayable_.ClearHilite();
            elementAgendaDisplayable_.Empty(true);
        public void Dispose()
            Dispose(true);
            GC.SuppressFinalize(this);
        protected virtual void Dispose(bool disposing)
            if (disposing)
                if (elementAgenda_ != null)
                    Empty();
                    elementAgenda_.Dispose();
        /// Add an element to our agenda.
        public void AddElement(Bentley.DgnPlatformNET.Elements.Element el)
            if (HighlightCriteria.SingleHighlight == highlightCriteria_)
                Empty();
            var dgnModelref = _dgnModelRef;
            if (dgnModelref is null)
                dgnModelref = el.DgnModelRef;
            var status = SelectionSetManager.AddElement(el, dgnModelref);
            var isActive = SelectionSetManager.IsActive();
            var status2 = SelectionSetManager.ReplaceWithElement(el, dgnModelref);
        /// Remove an element from our agenda so that it is no longer highlighted.
        public void RemoveElement(Bentley.DgnPlatformNET.Elements.Element el)
            el.Invalidate();
            SelectionSetManager.RemoveElement(el, dgnModelref);
Thanks!
