[CONNECT C++] CurverVector::CloneBetweenCyclicIndexedFractions()
I wish to "create" an arc from an ellipse. I have the fractions of the ellipse that I wish to clone between. However, I have a case where I need the portion of the ellipse that lies across the "end" (fraction =1.0) and extends to where the fraction is > 0.0. For example, I wish to clone the portion of the ellipse from the fraction 0.85 to 0.125. My attempts with
ellipse->CloneBetweenCyclicIndexedFractions(0, 0.85, 0, 0.125);
will return the portion from 0.125 to 0.85 and NOT the section from 0.85 to 0.125. Is it possible to return (i.e. Clone) across the start/end of an ellipse? I tried to clone two CurveVectors (0.0 to 0.125 and 0.85 to 1.0) then "Add()" them, but my tool immediately crashes:
CurveVectorPtr	Arc = ellipse->CloneBetweenCyclicIndexedFractions(0, 0.0, 0, 0.125);
CurveVectorPtr  Arc2 = ellipse->CloneBetweenCyclicIndexedFractions(0, 0.85, 0, 1.0);
Arc->Add(Arc2);
// crashes here creating the EditElementHandle
DraftingElementSchema::ToElement(eehArc, *Arc, nullptr, ACTIVEMODEL->Is3d(), *ACTIVEMODEL);
