If installed Connect Edition and my Listview in my vba apps doesn't exist anymore.
I have tried numerous MSCOMCTL.ocx files and no luck.
How do I get the Listviews to work in Connect Edition 13?
We are running the 64 bit version of Connect Edition.
MicroStation CONNECT Edition is 64bit application, so libraries referenced by VBA macros have to be 64bit also.
mscomctl.ocx is Microsoft library, not Bentley, so it's the question for Microsoft. I found an information that 64bit version of mscomctl.ocx was added to update 1707 of Office 365 Pro Plus (of course when 64bit Office is installed).
With regards,
Jan
civerson said:I installed Connect Edition and my ListView...
It's the same for everyone using 64-bit VBA: see this post about Excel VBA, for example.
Post questions about MicroStation VBA to the Programming Forum.
Hi, Civerson
Just wondering if you could finally solve what you were asking about last year.
We are in the same situation right now with CONNECT Edition update 14.
It'd be great if you could help us.
Thanks in advance,
Patricia
Patri said:Just wondering if you could finally solve what you were asking about last year
It's not a problem with MicroStation VBA that Bentley Systems can resolve. The ListView OCX is not delivered with VBA. If you're using it, then you've added a reference to an OCX installed on your computer. Probably, it was installed by another app. such as Microsoft Office.
The ListView control that you have used for 32-bit VBA is provided by Microsoft.
Read Jan's reply and follow his link to Office 365.
I used the ListBox in OpenCities Update 6.
Use a narrow listbox for the header.
Use a regular size listbox for the data.
Here is some code if it helps
subDisplayCurrentObstacleRecordBox(lTotalRec As Long, lCurrRec As Long, realCnt As Long, _ Optional oListBox As ListBox) ', Optional oListItem As ListItem) Const STRFORMAT As String = " " Dim i As Integer, findRec As Integer Dim maxstrlngth As Integer Dim actualCnt As Long Dim sCurrStat As String Dim name As String * 24 Dim maxstr As String Dim sName As String, sAdd As String ' Dim oListItems As ListItems ' Dim oListItem As ListItem ' Set oListItems = oListview.ListItems 'on error GoTo DCRErr
' SetHourGlass' Set oListItems = oListview.ListItems sCurrStat = "Row "' lst.Clear' CKI 10/16/2019 Changed from ListView to ListBox ' frmFeatRevw.lstViewPrimaryElem.ListItems.Clear frmFeatRevw.lstBoxPrimaryElem.Clear If obstacleRecord.BOF = True Then sCurrStat = sCurrStat & "(BOF) of " & lTotalRec ElseIf obstacleRecord.EOF = True Then sCurrStat = sCurrStat & "(EOF) of " & lTotalRec ElseIf realCnt = 0 Then sCurrStat = sCurrStat & "(EOF) of 0" Else sCurrStat = sCurrStat & lCurrRec + 1 & " of " & realCnt findRec = 0 ' loop to find the record that bSelections set to true to display ' exit the for loop when the record is found. For actualCnt = 0 To lTotalRec - 1 If bSelections(actualCnt) Then findRec = findRec + 1 End If If findRec = lCurrRec + 1 Then Exit For End If Next obstacleRecord.MoveFirst obstacleRecord.Move actualCnt maxstrlngth = 0 For i = 0 To obstacleRecord.Fields.count - 1 sName = obstacleRecord(i).name If Len(sName) < 22 Then sAdd = String(22 - Len(sName), " ") sName = sName & sAdd End If If obstacleRecord(i) <> vbNull Then ' lst.AddItem UCase(sName + strFormat + obstacleRecord(i)) ' Set oListItem = oListItems.Add(, , UCase(sName)) ' + strFormat + obstacleRecord(i))) ' CKI 10/16/2019 Changed from ListView to ListBox ' Set oListItem = frmFeatRevw.lstViewPrimaryElem.ListItems.Add(, , (UCase(Trim(sName)))) ' frmFeatRevw.lstViewPrimaryElem.ListItems(i + 1).SubItems(1) = obstacleRecord(i)
frmFeatRevw.lstBoxPrimaryElem.AddItem frmFeatRevw.lstBoxPrimaryElem.Column(0, frmFeatRevw.lstBoxPrimaryElem.ListCount - 1) = UCase(Trim(sName)) frmFeatRevw.lstBoxPrimaryElem.Column(1, frmFeatRevw.lstBoxPrimaryElem.ListCount - 1) = obstacleRecord(i)
Else ' lst.AddItem UCase(sName + strFormat + "") ' oListview.ListItems.Add UCase(sName + strFormat + "") ' CKI 10/16/2019 Changed from ListView to ListBox ' Set oListItem = frmFeatRevw.lstViewPrimaryElem.ListItems.Add(, , UCase(Trim(sName))) ' frmFeatRevw.lstViewPrimaryElem.ListItems(i + 1).SubItems(1) = "" frmFeatRevw.lstBoxPrimaryElem.AddItem frmFeatRevw.lstBoxPrimaryElem.Column(0, frmFeatRevw.lstBoxPrimaryElem.ListCount - 1) = UCase(Trim(sName)) frmFeatRevw.lstBoxPrimaryElem.Column(1, frmFeatRevw.lstBoxPrimaryElem.ListCount - 1) = "" End If Next ' if block to set the dismantled check box for records with ' obs_acode = "D"... Only works for obstacles 07 15 98 With frmMainProd If StrComp(.lstFeat.List(.lstFeat.ListIndex), "ORS OBSTACLE", 1) = 0 _ And .lstDocsofProd.List(.lstDocsofProd.ListIndex) <> "RECTANGULAR ALBUQURQUE SECTIONAL" Then If obstacleRecord!OBS_ACODE = "D" Then frmFeatRevw.chkDismantled.enabled = True frmFeatRevw.chkDismantled.Value = 1 Else frmFeatRevw.chkDismantled.enabled = False frmFeatRevw.chkDismantled.Value = 0 End If End If End With ' Compare width of longest string displayed in list ' box to width of list box. If width of longest string > ' width of list box, display a horizontal scroll bar for ' the list box. 02/12/98 gba ' SetHScroll frmFeatRevw, lst, maxstr End If
frmFeatRevw.lblStatus.Caption = sCurrStat
'Screen.MousePointer = vbDefault Exit Sub
DCRErr: ShowError Resume Next 'so we can try and display as much data as possible Exit SubEnd Sub
Hello, thank you so much for your answer!
We'd like to know which version of the file MSCOMCTL.OCX you used. Can you share this, please?
civerson said:I used the ListBox
Patri said: which version of the file MSCOMCTL.OCX
What exactly do you want?
There's another list viewer named ListCtrl. AFAIK that's also a 32-bit OCX with no 64-bit version.
According to the link provided by Jan, Office 365 and Office 2019 may provide a 64-bit version of MsComctl.ocx. You'll to talk with your IT support to find if (a) they will upgrade Office to 2019 and (b) whether they will install the 64-bit version of Office.
MsComctl.ocx
Hi, all
We are using MsComctl.ocx 64 bits and in VBA editor of excel I can see listview's control but not in MicroStation's VBA editor. Following you can see a screenshot.
Here is screenshot that shows MsComctl.ocx is 64 bits
Patri said:We are using MsComctl.ocx 64 bits and in VBA editor of excel
In the Excel VBE Editor (IDE) in Excel, do you see MsComCtl.ocx in the Tools|References dialog?
MsComCtl.ocx
Can you see the same in the MicroStation IDE? No? You must add a reference to MsComCtl.ocx in that dialog.
Hi, Joan
Yes, we have referenced it but it still doesn't work
Thanks!
