[MS V8i c++] a question about function ---- mdlBspline_oneRailTwoSectionSweep(&surface, &loftPath, &startCurve, &endCurve, &dirVecStart, &dirVecEnd, fc_epsilon)
while  I used this function, I constructed the parameters "loftpath" by two ways. one is start a tool of ElementSetTool, as the code below:
bool BaseLine::OnModifyComplete(MstnButtonEventCP ev)
	MSElementDescrP	pathEdP;
	EditElemHandleP start = GetElemAgendaP()->GetFirstP();
	pathEdP = start->GetElemDescrP();
	if (NULL != pathEdP)
		pathID = elementRef_getElemID(pathEdP->h.elementRef);
	mdlElmdscr_freeAll(&pathEdP);
	//start another command
	mdlInput_sendKeyin("ROADWAY PLACECOMPLETE", 0, 0, NULL);
	ExitTool();
	return true;
in the code above, i get the ElementID of the path,  then , i construct MSElementDescr of the path by its ElementID;
void BaseLine::TransformBathLine(MSElementDescrP *pathEdPP, Transform *pTrans)
	if (NULL == pathEdPP)
		return;
	mdlAssoc_getElementDescr(pathEdPP, NULL, pathID, ACTIVEMODEL, false);
	if (NULL != pTrans)
		mdlElmdscr_transform(*pathEdPP, pTrans);
then, my program nearly stop at the function mdlBspline_oneRailTwoSectionSweep(thought it worked right, but too slowly to stand)
In another way, i construct path by the code below:
	MSElement el;
	DPoint3d pts[3] = { { 0.0, 100000000, 0.0 },{ 0.0, 0.0, 0.0 },{ 0.0, -1000000000, 0.0 } };
	mdlArc_createByCenter(&el, NULL, pts, 0, 0, 2);
	mdlElmdscr_new(&pathEdP, NULL, &el);
my program works well:
the differece between two methods is just how i get descriptor of path;(the path is the same form)
i do not know why? and  i would appreciate it if you are so kind to help me.
